on 04-01-2022 11:33
I had to reset my hub 3 as my wifi showed ‘weak security’. Now my ring doorbell will not connect to WiFi or even set up.
Ive tried guest WiFi, setting it up on both 2g and 5G, deleting it and resetting my router again and again.
Nothing seems to work, I don’t want to have to start buying a new router etc as the doorbell worked perfectly fine before I reset my hub.
Can anyone help or advise? Thanks
on 07-01-2022 17:52
