29-07-2022 11:15 - edited 29-07-2022 11:16
we’ve just installed the Hub 4 (upgraded) and now can’t get our Ring doorbell to connect, never had any problems with Hub 3
on 29-07-2022 11:41
Rename the 2.4 and 5 GHz networks in router settings to the same as the old hub and bingo everything should auto re connect. If you do get any issues disable the 5 ghz band for several minutes let item connect then re enable the 5 ghz band.
This worked great for me when i went from the hub 3 to 4 and then to hub 5, saved me hours reconfiguring devices to connect to the network.
on 29-07-2022 12:29
on 31-07-2022 16:43
Hi there @pekarokiki
Thank you so much for your post and welcome back to the forums! It's great to have you here.
A big thank you to our community members @bitsandpcs and @legacy1 for their help with this so far!
Can I ask if you have been able to try the tips and steps provided?
Thank you.
on 02-08-2022 19:46
Thank you all for your help…I renamed the 5g, managed to connect the doorbell and then went back and put the 5g back to what it was…it is all working fine now thank you
on 05-09-2022 19:55
Can you give me instructions on how you rename the network? I’m having the same problem with my ring doorbell
on 05-09-2022 23:29
Open browser and in address bar type 192.168.0.1
Type in your password and login to your hub settings
Under the Quick setup wizards click on Click on 'configure your wifi networks'
Then rename the network to what your old network was on your old hub
Click apply and that should then rename both 2.4 and 5 networks
And hopefully your door bell will reconnect thinking it was the old router providing you have not changed the ring bell settings?
