Brendanfitz
Replacement hub
Hi I received a replacement hub because the last one stopped working. I tried to set up but need an activation code, I have not received this as my telephone number has changed as the number on the account is very old. What can I do? Thank you for your help.
  • 19.23K
  • 1.68K
  • 4.22K
Re: Replacement hub
would need to give virginmedia a call via 150 / 0345 454 1111 and they'll be able to active it for you.. could try the online chat via http://contact.virginmedia.com (using PC/laptop) but this is overused and understaffed
If someone's helped you out say thanks by clicking on the thumbs up on kudos. If someone's solved your problem, why not mark their message as an Accepted Solution, but only do this once issue has been resolved.
  • 6.04K
  • 464
  • 1.01K
Hero
Re: Replacement hub
You do not enter an activation code. VM activate it from their end, there should have been a telephone number in the package to call, if not phone customer services.
