on 09-12-2021 20:13
In recent weeks we have suddenly experienced frequent drops on wifi and on demand/network tv features. We typically notice it first whilst working/surfing on phones and then see Netflix/on demand features won’t work at the same time. Virgin tv is Ethernet wired to superhub.
A superhub restart resolves the issue but this is sometimes happening 2-3 times a day (not every day). 2 engineers and 2 replacement superhub a later and the issue persists. Setup worked fine 5 years and only arose last few weeks.
virgin support (WhatsApp chat) think it’s wifi connectivity issue and propose we pay £5 a month for wifi pod. But wired tv services drop too so I don’t believe this to be true and it happens at random times and maybe I’m away at work but wife is home. We are rarely both out to know if it drops whilst we are all out but plenty of always connected devices (ovens, smart speaker) and wired virgin tv.
any help is appreciated. Thank you
Answered! Go to Answer
on 09-12-2021 20:58
It's not completely clear from your post, so I'll ask for avoidance of doubt...
Are Ethernet cabled connections from your hub similarly affected? That will establish whether this is a broadband issue (that would affect all connections) or a router/wireless problem.
on 09-12-2021 20:58
on 10-12-2021 07:06
I have the virgin tv and Xbox connected by Ethernet cables. Virgin tv loses on demand/ Netflix/Amazon and only allows live tv and my recordings until the is superhub restarted. The Xbox admittedly I’ve not tried and will look at during the next dropout.
on 10-12-2021 07:21
on 10-12-2021 08:29
Acquired Downstream Channel (Hz) | 322750000 | Locked |
Ranged Upstream Channel (Hz) | 60300000 | Locked |
Provisioning State | Online |
on 10-12-2021 08:30
1 | 322750000 | 5.1 | 40 | 256 qam | 24 |
2 | 138750000 | 3.5 | 40 | 256 qam | 1 |
3 | 146750000 | 3.5 | 40 | 256 qam | 2 |
4 | 154750000 | 3.5 | 40 | 256 qam | 3 |
5 | 162750000 | 3.2 | 40 | 256 qam | 4 |
6 | 170750000 | 3.5 | 40 | 256 qam | 5 |
7 | 178750000 | 3.2 | 40 | 256 qam | 6 |
8 | 186750000 | 3.4 | 40 | 256 qam | 7 |
9 | 194750000 | 3.5 | 40 | 256 qam | 8 |
10 | 202750000 | 3.5 | 40 | 256 qam | 9 |
11 | 210750000 | 3.5 | 40 | 256 qam | 10 |
12 | 218750000 | 3.5 | 40 | 256 qam | 11 |
13 | 226750000 | 3.5 | 40 | 256 qam | 12 |
14 | 234750000 | 3.7 | 40 | 256 qam | 13 |
15 | 242750000 | 3.7 | 40 | 256 qam | 14 |
16 | 250750000 | 4 | 40 | 256 qam | 15 |
17 | 258750000 | 4 | 40 | 256 qam | 16 |
18 | 266750000 | 4.6 | 40 | 256 qam | 17 |
19 | 274750000 | 4.8 | 40 | 256 qam | 18 |
20 | 282750000 | 5 | 40 | 256 qam | 19 |
21 | 290750000 | 5.1 | 40 | 256 qam | 20 |
22 | 298750000 | 5.6 | 40 | 256 qam | 21 |
23 | 306750000 | 5.4 | 40 | 256 qam | 22 |
24 | 314750000 | 5.1 | 40 | 256 qam | 23 |
1 | Locked | 40.3 | 0 | 0 |
2 | Locked | 40.9 | 4 | 0 |
3 | Locked | 40.3 | 5 | 0 |
4 | Locked | 40.3 | 5 | 0 |
5 | Locked | 40.9 | 0 | 0 |
6 | Locked | 40.3 | 0 | 0 |
7 | Locked | 40.3 | 0 | 0 |
8 | Locked | 40.3 | 18 | 0 |
9 | Locked | 40.9 | 18 | 0 |
10 | Locked | 40.9 | 4 | 0 |
11 | Locked | 40.3 | 5 | 0 |
12 | Locked | 40.3 | 6 | 0 |
13 | Locked | 40.3 | 6 | 0 |
14 | Locked | 40.3 | 4 | 0 |
15 | Locked | 40.9 | 4 | 0 |
16 | Locked | 40.9 | 0 | 0 |
17 | Locked | 40.3 | 0 | 0 |
18 | Locked | 40.3 | 6 | 0 |
19 | Locked | 40.9 | 5 | 0 |
20 | Locked | 40.3 | 5 | 0 |
21 | Locked | 40.3 | 5 | 0 |
22 | Locked | 40.3 | 5 | 0 |
23 | Locked | 40.3 | 5 | 0 |
24 | Locked | 40.3 | 0 | 0 |
on 10-12-2021 08:30
1 | 60300000 | 43.8 | 5120 | 64 qam | 1 |
2 | 53700000 | 44.5 | 5120 | 64 qam | 2 |
3 | 46200000 | 44.8 | 5120 | 32 qam | 3 |
4 | 39400000 | 44.5 | 5120 | 64 qam | 4 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
on 10-12-2021 08:31
Network access | Allowed |
Maximum Number of CPEs | 1 |
Baseline Privacy | Enabled |
DOCSIS Mode | Docsis30 |
Config file | cmreg-vmdg505-bbt062+voc-b.cm |
SFID | 66096 |
Max Traffic Rate | 402500089 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
SFID | 66095 |
Max Traffic Rate | 38500089 |
Max Concatenated Burst | 42600 |
Scheduling Type | BestEffort |
on 10-12-2021 08:31
10/12/2021 08:06:4 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/12/2021 08:05:54 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/12/2021 08:04:49 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:01:35 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/12/2021 18:47:14 | notice | NOTICE ATOM is restarted as part of Self Healing Mechanism;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/12/2021 04:35:58 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/12/2021 19:00:58 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/12/2021 18:25:25 | notice | NOTICE ATOM is restarted as part of Self Healing Mechanism;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/12/2021 15:44:20 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/12/2021 18:30:11 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/12/2021 12:52:39 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/12/2021 12:24:29 | notice | SW download Successful - Via Config file |
04/12/2021 12:22:16 | notice | SW Download INIT - Via Config file |
04/12/2021 12:22:12 | Error | Disruption during SW download - Power Failure |
01/01/1970 00:02:6 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/12/2021 12:18:54 | notice | SW Download INIT - Via Config file |
01/01/1970 00:18:0 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:17:21 | critical | DHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:16:18 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:15:33 | critical | DHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 10-12-2021 16:34
Thanks, here is the live link.
I cant explain the red drop out for large portions of the day, the wifi is running. I have devices around the house and the VirginMedia Connect app shows strong signal in all rooms. But the superhub login and "Network Diagnostics Tools" claims all wifi devices have weak signal and to move closer to the superhub (3).
https://www.thinkbroadband.com/broadband/monitoring/quality/share/cbbd1a653879154ac25c34bcca38b67c0cc2d849
