f825_633
  • 32
Message 1 of 22
Reolink Camera not working on VM
Hello All.
I have a couple of Reolink cameras I have been given for test. When they were being used on a differnent connection they were viewable by the cloud app. Testing them on a VM connection they constanty disconnect from the app.
I've tried direct ethernet into the modem and via wireless.
I have also tried a EE 4G hotspot connecting them wirelessly and they are stable. its something odd with the VM internet connection.
Heres a traceroute ont he VM connection.
1 * * *
2 hers-core-2a-xe-810-0.network.virginmedia.net (80.3.33.113) 8.467 ms 12.502 ms 11.464 ms
3 * * *
4 tclo-ic-3-ae0-0.network.virginmedia.net (212.250.25.62) 8.458 ms 13.780 ms 8.364 ms
5 52.95.218.110 (52.95.218.110) 8.619 ms 9.586 ms 9.514 ms
6 54.239.100.134 (54.239.100.134) 16.926 ms 54.239.100.94 (54.239.100.94) 17.023 ms 54.239.100.54 (54.239.100.54) 17.524 ms
7 54.239.100.97 (54.239.100.97) 18.347 ms 54.239.100.163 (54.239.100.163) 30.076 ms 54.239.100.139 (54.239.100.139) 15.647 ms
8 54.239.45.227 (54.239.45.227) 35.032 ms 54.239.42.109 (54.239.42.109) 44.861 ms 54.239.42.107 (54.239.42.107) 24.001 ms
9 54.239.47.6 (54.239.47.6) 31.227 ms 52.93.128.160 (52.93.128.160) 28.339 ms 54.239.47.6 (54.239.47.6) 27.430 ms
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 ec2-34-240-214-13.eu-west-1.compute.amazonaws.com (34.240.214.13) 23.995 ms * 20.667 ms
Heres the traceroute on the original connection. which is stable.
traceroute to 34.240.214.13 (34.240.214.13), 30 hops max, 60 byte packets
1 lo5-t6-bng1.router.uk.clara.net (80.168.0.6) 9.358 ms 9.275 ms 9.210 ms
2 tengige0-0-0-3-t6-mse1.router.uk.clara.net (195.157.0.1) 9.879 ms 9.830 ms 9.858 ms
3 be1-t40-mse1.router.uk.clara.net (195.157.3.18) 10.058 ms 11.883 ms 11.824 ms
4 be1-t40-mse1.router.uk.clara.net (195.157.3.18) 9.415 ms 9.422 ms 9.337 ms
5 195.66.225.175 (195.66.225.175) 10.021 ms 9.922 ms 9.907 ms
6 * * *
7 * * *
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 ec2-34-240-214-13.eu-west-1.compute.amazonaws.com (34.240.214.13) 18.550 ms 18.456 ms 20.294 ms
Tags (3)
f825_633
  • 32
Message 2 of 22
Re: Reolink Camera not working on VM
VM : Can you offer any suggestions please.
I have even directly connected the camera with the VM box in modem mode which should be as clean and unfiltered connection as possible and the problem remains.
its definitly something on your side of the network blocking this.
Zoie_P
  • 2.88K
  • 135
  • 232
Message 3 of 22
Hi F825_633,
thanks for your post I am sorry we cannot support regarding 3rd party equipment, I would suggest you get in contact with the  gadget rescue team for assistance
thanks
Zoie
gary_dexter
  • 31.3K
  • 1.94K
  • 4.2K
Message 4 of 22
It’s leaving the VM network and also reaching the end destination.
There’s no issue with regards routing etc.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 22
How many devices have you got plugged into the Hub in Modem Mode ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 22
Are you using a switch in the system ?
jhuk
  • 3.03K
  • 52
  • 290
Problem sorter
Message 7 of 22
Disable Smart Optimisation in HUB3 or if HUB4 uncheck Auto and check manual for channels
If I do not do this I randomly loose some of my smaller/smart devices like Camera/Hamony Hub.
f825_633
  • 32
Message 8 of 22
I've connected one device directly to the hub in modem mode and it doesnt work.
If I use a 4G modem which we use at work when people are on site without a wired connection, it is a basic device with one ethernet, no wifi and designed to provide wired ethernet. it works fine with that. I took the camera next door and plugged it into their BT router and it came straigt up. I also setup a hotspot on my EE phone, connected that via USB to the laptop and then shared the connection to the ethernet port and plugged in the camera - very conveluted but it worked !. How does VM explain it works with other ISP's and not with them?
When its on the VM network something is happening enroute to prevent it working.
Somone else mentioned its not VM becuase the routing is working. Just becuase a route exists, it doesnt mean that the protocol that the cameras are using which I believe is RTSP is being passed across the VM network. traceroute uses ICMP packets which are entirely different. I already know that VM optomise their network for speedtest.net so the results look favourable. There could be all sorts of dark magic taking please.
gary_dexter
  • 31.3K
  • 1.94K
  • 4.2K
Message 9 of 22
Put the hub into modem mode and use your own router then
f825_633
  • 32
Message 10 of 22
Hello.
I did say int he original post that I had tried the hub in modem mode with it directly connected and it made no differrence.
At the moment to make it work, I have a raspberry pi running a VPN to NordVPN and the camera connected to that, so in effect the traffic reaching the reolink servers is coming from outside the VM network.
Its very clearly a problem on the VM network, talking to network consultant he said that VM maybe doing packet inspection which is altering the sequence of packets which causes reolink servers to reject the incoming stream becuase its out of sequence. He's seen this sort of thing before whilst working in broadcast and using the public internet to move streams about. He said if you manage to convince VM that the problem exists its highly unlikely they will have any idea of how to resolve it. It was him that suggested the raspberry pi soltuion which is working a treat.
