on 15-11-2022 17:49
Hello,
some assistance please. I'm getting regular broadband 'drop-outs' and network connectivity issues and I'd like to know what I can do / where I can go next. My router's is in modem mode. I'm connecting from multiple devices (wired and wi-fi) and when browsing, using twitter etc. I'm having very long lags. And when using a PC I get DNS errors, can't find server etc. These subsequently resolve themselves. Also when downloading some files I get disconnected with a network error. I've had 3 separate engineers here: One fixed a 'crooked' cable; one put an attenuator (I think) to help in signal strength and I can't remember what the other one did. Also a network engineer attended to fix an issue in the 'green box' (I can't remember what you call it) outside where I live. I'm still having problems. Looking at the error log there are infrequent T3 errors. I've noticed from other messages that they've provided information from the error log. It follows. Can anybody help?
14/11/2022 11:38:31 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=******************;CMTS-MAC=******************;CM-QOS=1.1;CM-VER=3.0;
11/11/2022 00:09:5 critical No Ranging Response received - T3 time-out;CM-MAC=******************;CMTS-MAC=******************;CM-QOS=1.1;CM-VER=3.0;
10/11/2022 23:38:31 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=******************;CMTS-MAC=******************;CM-QOS=1.1;CM-VER=3.0;
08/11/2022 07:28:18 critical No Ranging Response received - T3 time-out;CM-MAC=******************;CMTS-MAC=******************;CM-QOS=1.1;CM-VER=3.0;
07/11/2022 11:38:31 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=******************;CMTS-MAC=******************;CM-QOS=1.1;CM-VER=3.0;
05/11/2022 03:23:48 critical No Ranging Response received - T3 time-out;CM-MAC=******************;CMTS-MAC=******************;CM-QOS=1.1;CM-VER=3.0;
04/11/2022 17:58:43 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=******************;CMTS-MAC=******************;CM-QOS=1.1;CM-VER=3.0;
01/11/2022 14:47:7 critical No Ranging Response received - T3 time-out;CM-MAC=******************;CMTS-MAC=******************;CM-QOS=1.1;CM-VER=3.0;
30/10/2022 16:18:14 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=******************;CMTS-MAC=******************;CM-QOS=1.1;CM-VER=3.0;
27/10/2022 07:06:21 critical No Ranging Response received - T3 time-out;CM-MAC=******************;CMTS-MAC=******************;CM-QOS=1.1;CM-VER=3.0;
23/10/2022 16:18:14 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=******************;CMTS-MAC=******************;CM-QOS=1.1;CM-VER=3.0;
23/10/2022 13:52:47 critical No Ranging Response received - T3 time-out;CM-MAC=******************;CMTS-MAC=******************;CM-QOS=1.1;CM-VER=3.0;
20/10/2022 04:18:14 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=******************;CMTS-MAC=******************;CM-QOS=1.1;CM-VER=3.0;
18/10/2022 17:06:8 critical No Ranging Response received - T3 time-out;CM-MAC=******************;CMTS-MAC=******************;CM-QOS=1.1;CM-VER=3.0;
16/10/2022 16:18:14 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=******************;CMTS-MAC=******************;CM-QOS=1.1;CM-VER=3.0;
14/10/2022 15:01:46 critical No Ranging Response received - T3 time-out;CM-MAC=******************;CMTS-MAC=******************;CM-QOS=1.1;CM-VER=3.0;
13/10/2022 04:18:14 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=******************;CMTS-MAC=******************;CM-QOS=1.1;CM-VER=3.0;
10/10/2022 13:13:40 critical No Ranging Response received - T3 time-out;CM-MAC=******************;CMTS-MAC=******************;CM-QOS=1.1;CM-VER=3.0;
09/10/2022 16:18:14 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=******************;CMTS-MAC=******************;CM-QOS=1.1;CM-VER=3.0;
08/10/2022 16:34:54 critical No Ranging Response received - T3 time-out;CM-MAC=******************;CMTS-MAC=******************;CM-QOS=1.1;CM-VER=3.0;
1 203000000 3 37 256 qam 9
2 139000000 3.9 36 256 qam 1
3 147000000 4 36 256 qam 2
4 155000000 4.3 36 256 qam 3
5 163000000 4 37 256 qam 4
6 171000000 4.3 37 256 qam 5
7 179000000 3.9 37 256 qam 6
8 187000000 3.9 37 256 qam 7
9 195000000 3.4 37 256 qam 8
10 211000000 3 37 256 qam 10
11 219000000 2.5 37 256 qam 11
12 227000000 2.5 37 256 qam 12
13 235000000 2 37 256 qam 13
14 243000000 1.9 37 256 qam 14
15 251000000 2 37 256 qam 15
16 259000000 2.2 37 256 qam 16
17 267000000 2.4 37 256 qam 17
18 275000000 2.5 37 256 qam 18
19 283000000 2.5 38 256 qam 19
20 291000000 2.7 38 256 qam 20
21 299000000 2.5 37 256 qam 21
22 307000000 2.7 38 256 qam 22
23 315000000 2.5 38 256 qam 23
24 323000000 2.4 37 256 qam 24
1 Locked 37.3 289 0
2 Locked 36.6 1066 0
3 Locked 36.6 515 0
4 Locked 36.6 320 0
5 Locked 37.6 248 0
6 Locked 37.6 215 0
7 Locked 37.6 197 0
8 Locked 37.3 336 0
9 Locked 37.3 230 0
10 Locked 37.3 333 0
11 Locked 37.6 221 0
12 Locked 37.3 430 0
13 Locked 37.3 260 0
14 Locked 37.3 290 0
15 Locked 37.3 401 1
16 Locked 37.3 209 0
17 Locked 37.6 181 0
18 Locked 37.6 232 0
19 Locked 38.6 164 0
20 Locked 38.6 238 0
21 Locked 37.6 204 0
22 Locked 38.9 127 0
23 Locked 38.6 235 14
24 Locked 37.6 133 0
Welcome back!
Sign in to view or modify your Hub 3.0 settings.
Password
Router status
Status
Downstream
Upstream
Configuration
Refresh data
1 49600005 43.5 5120 64 qam 1
2 23600000 41.5 5120 64 qam 5
3 43100000 43 5120 64 qam 2
4 30100000 41.8 5120 64 qam 4
5 36600000 42.3 5120 64 qam 3
1 ATDMA 0 0 0 0
2 ATDMA 0 0 2 0
3 ATDMA 0 0 4 0
4 ATDMA 0 0 0 0
5 ATDMA 0 0 0 0
on 16-11-2022 15:42
on 16-11-2022 17:24
Hello,
thanks for the input. The router is a TP-Link ac1750 (there's also a gigabit switch a TLSG810E). What confused me is that the configuration was working quite happily for months on end. And a few months ago the problems started happening. And I could not associate anything I'd changed with the issue. I'll go back and check the forums for the correct sequence connection. Is the implication that it's internal rather than external? I've started a broadband quality monitor today and this is what I've got so far but I don't know how to interpret it:
Thanks for any help.
on 16-11-2022 17:38
Oops, here's the picture
on 17-11-2022 12:24
Here's a 24-hour sample. The spike at 09:20 corresponds with a download. Can anyone explain this? It's beyond my abilities. Ta.
on 17-11-2022 15:16
on 17-11-2022 15:21
OK, thanks. I'll have to revisit the whole home setup. Thanks for your help.
