on 18-05-2022 08:45
Hi I have a Hub 4 and one pod to help with poor wifi upstairs. I had to rename wifi bands to connect smart plugs.
Do In need to do anything to get the pod to connect to newly named networks?
Answered! Go to Answer
on 18-05-2022 08:51
they should work - the 2 bands need to be joined although they do seem to work if they are split but wifi optimisation must be on
on 18-05-2022 08:51
on 18-05-2022 11:11
on 18-05-2022 12:31
My understanding is that the pods will only work with a combined SSID name, if you have give your SSIDs individual names I believe they will not work.
18-05-2022 14:42 - edited 18-05-2022 14:49
@Tudor wrote:My understanding is that the pods will only work with a combined SSID name, if you have give your SSIDs individual names I believe they will not work.
thats what the script says but i have tried mine with different names and they worked - its a while since so things may have changed
on 18-05-2022 14:45
Do VM staff monitor this board?
If so can you provide a definite of answer please
on 18-05-2022 14:52
on 20-05-2022 15:47
Thanks for posting amb3.
Our apologies for any confusion with the Pod's and the split WiFi bands.
We would need the WiFi bands to be merged as one with Smart WiFi activated on the Hub settings as well.
Please let us know if we can assist further.
