TMcGRed
  • 7
Message 1 of 13
Renaming Connected Devices Hub 4
Just received a new Hub 4, was looking forward to getting it set up as I have patchy wifi in my bedroom from the Hub 3.
Set up was straight forward, renamed the SSID & password to be the same as the old Hub 3 so all my devices would automatically connect.  So far, so good.....
Then I tried renaming my connected devices - as I wasn't able to import the Hub 3 config file 😞
My advice - don't bother renaming as it doesn't work!!!!!   My phone appeared 'Samsung S9' tried renaming it and it updated another device's name instead!!  I've got 15 devices that I'd like to rename, bit it's impossible.  God knows what it's doing - but this needs fixing....Virgin!!!!!
Tags (2)
  • 2.87K
  • 214
  • 610
Trouble shooter
Message 2 of 13
Re: Renaming Connected Devices Hub 4
@TMcGRed wrote:
Just received a new Hub 4,   <snip>   as I wasn't able to import the Hub 3 config file 😞   <snip>
That would be correct.  It's completely different hardware and firmware.
gary_dexter
  • 30.32K
  • 1.88K
  • 4.03K
Message 3 of 13
Why do you need to name the devices?
Also getting a Hub4 thinking it would be better than a Hub3 is just crazy talk!!
TMcGRed
  • 7
Message 4 of 13
You rename your devices so you know exactly what's connected to your network.
Most wifi connected devices have non-descript names that have no relation to the device.
Re naming makes it straight forward to ID what the device is & makes it easy to spot any new / dodgy connections.
Anonymous
Not applicable
Message 5 of 13
or just don't give your wifi password to anyone and you know whats connected
gary_dexter
  • 30.32K
  • 1.88K
  • 4.03K
Message 6 of 13
Use MAC filtering.
Set a strong 16 character minimum password.
Don’t share your password.
etc.
TMcGRed
  • 7
Message 7 of 13
Never heard of hackers?
I don't give out the wifi password to random strangers.
Numpty!
gary_dexter
  • 30.32K
  • 1.88K
  • 4.03K
Message 8 of 13
Hackers huh?
Oh dear.
Anonymous
Not applicable
Message 9 of 13
I've met more paranoid people then hackers 🙂
I can recommend some cyber security consultants if you are really worried 🙂
TMcGRed
  • 7
Message 10 of 13
My God!!
Ask a simple question / report an issue... and what do you get?!!
Bloody know-it-all trolls.
Jeez, if you read my original post, I just want to rename my devices on the router.
Hub 3 worked fine with this, Hub 4 doesn't.
I've worked in IT for 20+ years so know what I'm doing thanks 😏
Over & out.
