  • 17
RyanM
Regular connection problems
For the past few weeks, we've had frequent problems with broadband.  When running a ping test, there has been regular packet loss.  Yet when using Virgin Media's broadband checker a problem is never found (even whilst observing a significant amount of ping drops whilst it's running).  I've left constant pings running from my PC and also used an external ping checker too.
From a recent ping test against google.co.uk:
Packets: Sent = 271, Received = 243, Lost = 28 (10% loss)
At first, I thought it was my Asus router, so I switched the Virgin Media cable modem out of modem-only mode and experienced the same problems (in fact the above is from whilst using the Virgin Media Super Hub as my router - it's the original Super Hub).
I'm going to (finally) call up tomorrow, but wondered if anyone on the forum has any thoughts about the cause of the problem.
I haven't been connected for long, but here are the stats from Network Status:
Downstream ChannelsLock Status Channel ID Frequency Modulation Rx Power SNR Pre RS Errors Post RS Errors
Locked1139000000 HzQAM256-4.6 dBmV38.6 dB18081361484
Locked2147000000 HzQAM256-4.8 dBmV38.9 dB16409151472
Locked3155000000 HzQAM256-5.9 dBmV38.6 dB293230154749
Locked4163000000 HzQAM256-5.8 dBmV38.6 dB358226215133
Locked5171000000 HzQAM256-3.2 dBmV39.0 dB17499155383
Locked6179000000 HzQAM256-3.7 dBmV38.6 dB12760031433
Locked7187000000 HzQAM256-4.5 dBmV38.6 dB12820331362
Locked8195000000 HzQAM256-4.9 dBmV38.5 dB13378135661
Upstream ChannelsLock Status Channel ID Frequency Modulation Tx Power Mode Channel Bandwidth Symbol Rate
Locked532600000 HzATDMA50.8 dBmV64QAM640000030720 Kbits/sec
Locked253700000 HzATDMA50.8 dBmV64QAM640000030720 Kbits/sec
Locked439400000 HzATDMA50.8 dBmV64QAM640000030720 Kbits/sec
Locked346200000 HzATDMA50.8 dBmV64QAM640000030720 Kbits/sec
  • 6.14K
  • 470
  • 1.02K
Hero
Re: Regular connection problems
Stats are bad, downstream are just in spec, must be higher than -6 and upstream are too high, must be 50 or lower. You need a technician to correct. Call customer services and report the fault.
  • 1.54K
  • 85
  • 156
Re: Constant connection problems
Hi RyanM,
Sorry to hear you are having issues with your connection.
I would like to invite you into a private chat so I can look into this for you, I will send you an invite, please click on the purple envelope to accept.
Many thanks
Paul.
