  • 585
  • 8
  • 20
jaztim
Fibre optic
Message 1 of 28
Reeboots and Resets
Hi, I have a Hub 3.0
There has been a good few losses of service on last few weeks, once all night and others for a few hours etc.. I know there was work going on via service status page, however my router has factory reset itself 3 times in last few days. This is no good at all, can admin / staff please check from their end, power and things.
Router status Status Downstream Upstream Configuration Network Log Refresh data Downstream bonded channels Channel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID 1 371000000 -0.4 40 256 qam 26 2 195000000 -1 40 256 qam 8 3 203000000 -1.7 38 256 qam 9 4 211000000 -1 40 256 qam 10 5 219000000 -0.7 40 256 qam 11 6 227000000 -0.5 38 256 qam 12 7 235000000 -0.4 40 256 qam 13 8 243000000 -0.2 40 256 qam 14 9 251000000 -0.2 40 256 qam 15 10 259000000 -0.2 40 256 qam 16 11 267000000 0 40 256 qam 17 12 275000000 0 40 256 qam 18 13 283000000 0 40 256 qam 19 14 291000000 0.2 40 256 qam 20 15 299000000 0.4 40 256 qam 21 16 307000000 0.2 40 256 qam 22 17 315000000 0 40 256 qam 23 18 323000000 0 40 256 qam 24 19 363000000 -0.9 40 256 qam 25 20 379000000 0 40 256 qam 27 21 387000000 0 40 256 qam 28 22 395000000 0 40 256 qam 29 23 403000000 0 40 256 qam 30 24 411000000 0.4 40 256 qam 31 Downstream bonded channels Channel Locked Status RxMER (dB) Pre RS Errors Post RS Errors 1 Locked 40.9 620 3437 2 Locked 40.9 466 4482 3 Locked 38.9 591 4532 4 Locked 40.3 470 5407 5 Locked 40.9 504 5572 6 Locked 38.9 489 5417 7 Locked 40.9 533 5317 8 Locked 40.9 524 5955 9 Locked 40.3 509 5988 10 Locked 40.3 520 5502 11 Locked 40.3 564 5270 12 Locked 40.3 561 4916 13 Locked 40.9 569 4784 14 Locked 40.3 560 4531 15 Locked 40.3 560 4491 16 Locked 40.3 509 4435 17 Locked 40.3 570 4068 18 Locked 40.3 531 3801 19 Locked 40.3 562 2993 20 Locked 40.9 574 5843 21 Locked 40.9 577 6385 22 Locked 40.3 573 7001 23 Locked 40.9 614 809 24 Locked 40.3 534 995 Refresh data Upstream bonded channels Channel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID 1 46200031 5.1 5120 64 qam 11 2 32600078 5.1 5120 64 qam 13 3 39400031 5.1 5120 64 qam 12 4 53700043 5.1 5120 64 qam 10 Upstream bonded channels Channel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts 1 ATDMA 0 0 0 0 2 ATDMA 0 0 0 0 3 ATDMA 0 0 0 0 4 ATDMA 0 0 0 0
  • 9.42K
  • 978
  • 1.48K
Message 2 of 28
Re: Reeboots and Resets
If there is a known problem being worked on you will need to wait until that's resolved (keep checking - calling in) then switch the Hub off for a few minutes and restart, and then post up stats again if there is no improvement (with better formatting if you can!).
  • 585
  • 8
  • 20
jaztim
Fibre optic
Message 3 of 28
There's no known one last few days, the issue has still happens
  • 9.42K
  • 978
  • 1.48K
Message 4 of 28
OK if you got the all clear. Your upstream power looks maxed out to me - someone more qualified will comment. You have a lot of Post RS errors too - these might be historical due to the "problem". So switch the Hub off for a minute or two and restart it - check in there to see that the errors have reset to 0 and then check every couple of hours over the next day or so and see if they start building up. If so, post the stats up up again
  • 585
  • 8
  • 20
jaztim
Fibre optic
Message 5 of 28
To be fair, the router has had plenty of reboots and restarts over last week.
Would power issues / local area work cause 3 factory resets? I shouldn't think so.
  • 585
  • 8
  • 20
jaztim
Fibre optic
Message 6 of 28
Arrrrrrrghhh!!! Just came home from work to the router factory reset, again.. That's 4 times in a week. Come on staff / admins let's get this sorted.
22/02/2019 13:57:20 critical Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/02/2019 13:57:21 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/02/2019 13:57:40 critical Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/02/2019 13:57:40 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/02/2019 13:58:1 critical Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/02/2019 13:58:1 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/02/2019 13:58:21 critical Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/02/2019 13:58:21 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/02/2019 14:06:8 critical Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/02/2019 14:06:9 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/02/2019 14:06:28 critical Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/02/2019 14:06:29 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/02/2019 14:07:8 critical Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/02/2019 14:07:8 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/02/2019 14:07:28 critical Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/02/2019 14:07:28 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/02/2019 14:07:48 critical Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/02/2019 14:07:48 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/02/2019 14:07:56 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/02/2019 14:28:52 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 12.6K
  • 482
  • 1.12K
Message 7 of 28
Does the reset happen when in modem mode? If not maybe get your own router with 1Gb ports.
  • 585
  • 8
  • 20
jaztim
Fibre optic
Message 8 of 28
@legacy1 wrote:
Does the reset happen in modem mode? If not maybe get your own router with 1Gb ports.
No, It's in router mode. I've had many of my own Routers over the years and up until this episode of resets I've been very happy with hub 3 and its performance TBH.
  • 12.6K
  • 482
  • 1.12K
Message 9 of 28
Given how poorly done the hub 3 router mode is its WAN IP is facing the internet and anything to it could cause it to reset as a fail safe.
Can you try modem mode and see if it resets.
  • 585
  • 8
  • 20
jaztim
Fibre optic
Message 10 of 28
No longer have my own router, so unfortunately not at this time.
