on 29-07-2022 15:25
Hi. Please I have a red light showing on my hub. No Internet.
on 29-07-2022 15:38
on 29-07-2022 15:45
Hi Kdmma,
Thank you for reaching out to us in our community and welcome, sorry to hear you have no connection and a red light on the Router, I was able to locate you on our system with the details we have for you, I can see you have a 3rd poart Router and have ours in Modem mode, this is the reason the red light is on and is perfectly normal.
Please can you try a pin reset on our Router which will also take it out of Modem mode and put it back as it was when received and remove any password changes ETC.
Push a pin in the reset hole and hold in for a timed 1 minute, allow 15 minutes to settle.
Paul.
