Settling in
Red phone light flashing and Internet not working
The red phone light on my router is flashing and the Internet isn't working. Tried reseting and reconnecting all the cables but hasn't helped.
Any advice, please?
  • 7K
  • 517
  • 906
Legend
Re: Red phone light flashing and Internet not working
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 14.9K
  • 1.17K
  • 3.48K
@davidwright246 wrote:
Any advice, please?
whats the base light on the hub doing - if its flashing green is likely to be an external fault - ring it in and see if there is any help - it will likely sort itself out if its external work
____________________
Tony
