on 29-07-2024 19:16
After two very unhelpful telephone calls to Virgin Media customer services, I have now had to resort to this forum in order to get closure on the red light issue with our hub 3.0.
The hub has been permanently showing a solid red light for the past 2 weeks and rebooting and factory reset has failed to clear this issue, the hub is also very well ventilated.
The hub was installed in 2017, therefore it has worked constantly since then without any issues until now.
Doing my research on this forum and online tells me that the solid red light is a sign of overheating and possible failure at any given time.
Please could a moderator help me with this hub problem as the only solution I can see is replacing the hub for a new one.
Kindest regards
Allan Garwood
on 29-07-2024 19:44
Hi there @Allangarwood 👋 Welcome to our forum and thanks for your post 😊
We're sorry to see that you're having issues with the Hub having this red light. Thanks for trying the reboot as we'd usually advise.
Most of the time the issue is just the Hub light, but other times it could lead to overheating so we would usually replace them just to be safe. I'll pop you a PM to confirm some details so this can be done.
Nathan
