on 09-08-2022 17:28
I have had a red solid light on my hub 3 since February...its not overheating as its in the open...but have noticed lately my signal keeps dropping out...
on 09-08-2022 17:40
Have you tried rebooting, and then, if still the same, factory reset?
Try that and if no joy might need a new hub - call or wait for a rep to arrange a technician visit.
on 09-08-2022 17:49
Hello Johnie68,
Thanks for your first post and welcome to our Community.
Sorry to hear you are having an issue with the red light on the Hub
I'd like to take a look into this for you.
If you can check the purple envelope top right of your screen that would be great.
In the meantime, can you ensure its in a well ventilated place out of any direct source of heat.
Gareth_
09-08-2022 18:38 - edited 09-08-2022 18:45
Thanks for those details Johnie68,
Can you please let us know how the visit goes and how the replacement Hub is.
Gareth_L
on 12-08-2022 14:09
Hello Johnie68,
Just a quick message to see how the visit went and has the Hub been swapped over?
Gareth_L
on 17-08-2022 11:30
Swapped the hub over to the hub 5...was away all weekend came home Monday and noticed the light was flashing green...had to do a reboot but ok now
on 19-08-2022 11:43
Hi @Johnie68,
Thank you for the update on this. I'm glad to hear that things have now improved with your router and broadband service.
Please do let us know if there's anything more that we can help you out with.
