Red light showing on hub3
Simbra
My hub 3 router is showing a solid red light. From other messages, seems like this is showing an over heating router. Have tried resetting and turning off and on
Any ideas what else I could try?
2 REPLIES 2
If the Hub 3 red LED persists after a pinhole reset, the Hub should be swapped out. This red LED is the overheat warning and should be working correctly. If you wait here a couple of days a VM Mod should pick this up and discuss directly with you.
Molly_T
Hi Simbra 👋 Welcome to the community forum! Thanks for posting!
Sorry to hear about these issues with a constant red light on your hub.
Let's take a closer look via PM, and then we can arrange an engineer or replacement if needed.  You can find the PM in the top right corner of the page in your Inbox. 📩 We can then return to this public thread with another update when possible. Thank you for your patience in the meantime!
Wishing you all the best. 🌞
Molly
