on 10-07-2022 07:29
I have the red light on the hub for the last 48 hours. I note this cannot be ignored from other threads on this.
I’ve rebooted the hub, it’s in a well ventilated area. Not sure what else I can do? The hub is a number of years old so maybe it needs replacing?
on 10-07-2022 11:28
Hey geoack, thank you for reaching out and I am sorry you've got a red light on your hub.
I am going to send you a PM, please look out for the purple envelope.
In the meanwhile please can you try these steps;
• Then use the power switch to turn the unit back on. The Hub should now operate normally. Thanks
Matt - Forum Team
New around here?
on 10-07-2022 14:48
I have tried this and it has not worked.
Have not received your PM either?
thanks,
george
on 12-07-2022 15:31
Hey there @geoack, thanks for reaching out to us.
Thanks for letting us know with the update regarding the hub.
I will investigate this further and send you a private message - watch out for the purple envelope 🙂
Kind regards.
