on 07-07-2022 21:11
I've noticed the base light is a solid red on my Virgin hub 3 , i have read on various virgin forums that this is a safety issue with overheating... I've followed advice about resetting and have even left it switched off but when i switch it back on it is still red...
Could someone please advise as i am getting concerned...
on 08-07-2022 08:20
Hi opusnine,
Thanks for posting on our community forums. Sorry that you're experiencing issues with your hub currently, and that you have a constant red light.
We appreciate you re-setting your hub and performing a reboot already. Can we ask if the hub is hot to touch? Also, is the hub in an open space so it is getting air circulated to it?
Please let us know, so we can assist you further.
on 08-07-2022 08:46
Sorry i should have put this info in the original post
yes the hub is in space and not boxed in
When i did the factory reset the hub felt hot to touch..
Thanks...
on 09-07-2022 09:46
see also this new thread that the OP has started
https://community.virginmedia.com/t5/Networking-and-WiFi/Red-light-on-hub-3/td-p/5062562
Can a VM rep respond to the customer please.....
on 11-07-2022 12:17
Hey @opusnine, thanks for the reply.
As you've mentioned it feels hot to touch I will investigate this further.
I will send a private message - watch out for the purple envelope.
Kind regards.
