Red light on hub 3
Dave4367
Hi I’ve had a red light showing on my hub for over a week now.  I’ve tried popo, 10 second reset and 50 second reset.  All cable connections removed/reseated/tightened..
diagnostics run on app finds no problem
anybody have any ideas what to do next?
thanks
dave
5 REPLIES 5
MatthewS1993
Dialled in
New modem needed I’m afraid
If I've helped in any way, please give me Kudos and mark my response as a helpful answer!
I am a serving Field Technician at Virgin however all responses on here are based on my experiences in the field alone and my own equipment at home and should be taken as such
Zak_M
Good evening Dave4367
Welcome back to the forums and thank you for taking the time to post.
I am sorry to hear that you are having some issues with your hub.
Please can you just confirm that you are in router mode and not modem mode?
Kind regards,
Zak_M
Hi Zak, def in router mode.
So who do I contact to get a new hub?
Hi @Dave4367
Sorry for the delay in responding to you and the issues you've been experiencing.
I'm going to direct message you as we'll need to book a technician to replace the router.
Here to help 🙂
Virgin Media Forums Agent
Carley
