on 26-11-2022 12:06
Hey all. Our VM hub has a solid red light but has lots of space around it and doesn’t feel hot to the touch. I’ve tried a reset and no change. Does this need a replacement?
cheers.
on 26-11-2022 12:47
Please confirm it’s a Hub3.
on 26-11-2022 13:02
It is a hub 3 yes
on 26-11-2022 15:01
Hi @robjmills,
Thanks for your post, and a warm welcome to our Community Forums.
I'm sorry to hear you're seeing a red light on your Hub. Can you please try the following:
• Then use the power switch to turn the unit back on. The Hub should now operate normally and the red light should be gone.
on 04-12-2022 14:03
Tried all above and turns back on red.
on 06-12-2022 14:12
Thanks for coming back to us robjmills, from checking the connection and equipment the equipment is showing as fine so the red light might be an LED issue but there are some problems with the power levels. They aren't massively out of spec but we'd like to arrange a technician to take a closer look.
I will send you a Private Message to get some more details from you.
Rob
