Red light hub 3 always on despite resetting several times
mrmildew_
I have tried resetting via pin hole and on/off switch many times and the red light is still on!
4 REPLIES 4
Daniel_Et
Hi @mrmildew_👋 Thank you for your post and welcome to the Virgin Media Community 😀
We're sorry to hear about the problem you're experiencing 😔
Can you please confirm you've followed the following steps exactly:
• Turn the power switch off on the back of the Hub
• Ensure the Hub is upright, in a well-ventilated location, and, if at all possible, out of direct sunlight
• Use the power switch to turn the unit back on
If after following the steps the router doesn't boot back up after a few minutes, or the red light returns when it does, the router will need replacing.
Regards.
Daniel
Hi Daniel
I have tried all of the above options that you have suggested
Travis_M
Thank you for your response @mrmildew_
Keep an eye on your inbox for a message from myself so we can confirm some more details and have this resolved for you.
Travis_M
Ayisha_B
Hi @mrmildew_
Thanks for the update via PM.
We're glad this is sorted now following a hub swap by the technician.
If we can help with anything else, let us know.
Have a lovely weekend 😊
Ayisha_B
