on 25-05-2023 17:22
Hello people, I live in London SE18.
In the last few months I have experienced recurrent problems with the stability of the network and I find myself turning off/on the modem. Additionally I have a 1gbit contract, but my speed, although quote fast tends to drop below the minimum guaranteed quite often. Considering that soon my contract will switch to a full fee, I am not particularly impressed with the service. Is anyone living in the area or near by experiencing the same?
on 25-05-2023 18:15
Hi @Emanuele
Have you used the /check-services/i function? You can also a run a test on your equipment from there.
If nothing is showing you could also try the automated Service Status number 0800 561 0061. This often gives details of more local issues down to postcode level.
on 28-05-2023 09:28
Hi @Emanuele
Welcome back to our community forums and sorry to hear you are having unreliable WiFi. We can understand the inconvenience caused and we want to best help. I have had a look into your hub data and everything seems in order.
In this case, are you able to clarify if the problem is solely on wireless devices or on wired devices too? If so, you may find the following link useful https://virg.in/wifisos
on 28-05-2023 09:34
Thanks people, let's say that at the moment everything looks like functioning properly although throughout we did have some "hiccups" which from a top tier service and subscription I wouldn't expect... Let's see when the contract expires how my mood will be 😂 thanks for the support though
on 30-05-2023 11:14
Hi Emanuele,
Thanks for the update on this. I'm glad to hear things are looking all good. Please do let us know if you need anything else, and we'll do our best to assist further.
Cheers,
