3 weeks ago
3 weeks ago
Hi @Millsy87,
I'm very sorry to hear you're getting a solid red light on the router. If you haven't done so already, please follow each of the steps listed below.
• Then use the power switch to turn the unit back on. The Hub should now operate normally.
If the issue remains despite following those steps then please respond to the private message I'll be sending your way shortly and we'll assist you further from there.
