Re: Red light on hub
SallyEmma
Hi, I seem to have the same problem.  Red light on hub continuously.  I've tried restarting, rebooting, and turning off overnight. Hub in well ventilated place,  away from storage heater and window, but no problem with connection, and hub doesn't feel hot.
2 REPLIES 2
Hero
Assuming this is a Hub 3 ... It can be the LED fading or it can an over temperature fault.
To check login in to the Hub 3 menu at http://192.168.0.1/
use the numeric HUB PASSWORD from the bottom side label. ( this is not the Wi-Fi password )
Run the Network diagnostic tool
Scroll down through the results and find the Temperature entry. Is it normal ?
Lee_R
Hi @SallyEmma thanks for posting and welcome to our community.
Sorry to hear of your hub 3 having a constant red light and for any concerns this may be causing. I would like to take a look on your behalf. I am going to send you a private message. Please keep an eye on your inbox in the top right of your screen.
Lee_R
