on 19-09-2021 13:28
Hey buddy, I'm meeting exactly the same problem, did you solve it?
on 19-09-2021 14:43
on 21-09-2021 15:00
Hi MarekZhang,
Have you been able to reset the hub? We also do have the instructions here: https://www.virginmedia.com/help/virgin-media-reset-your-hub
Let s know if you need further help.
Cheers,
Corey C
on 27-09-2021 08:59
Hi Corey,
It seems that the modem does not work. One technician reached to me last Friday and helped me change it.
Cheers,
Mark
29-09-2021 09:06 - edited 29-09-2021 09:07
Hi there @MarekZhang
That you for updating! I just wanted to check is everything OK for you now?
Thanks again.
on 29-09-2021 09:10
Yeah, everything works right now.
Cheers,
Mark
on 01-10-2021 10:56
Thank you for letting us know Mark 🙂
Glad to hear this is all sorted for you.
