on 11-09-2022 12:01
I have the exactly the same experience. every time the Hub 4 getting suck then manually power cycle it. Everything resume except for those device running on 2.4G wifi. So the problem is on 2.4G wifi SSID being reset to the default name. How can I get the firmware fix?
on 11-09-2022 12:34
You need to 'Disable Channel Optimisation' in the Hub4 settings.
I have had no issues with SSID reverting back to their defuslt names, after I changed that setting.
Hope this helps you
on 13-09-2022 13:15
Hey MTSweet, thank you for reaching out and I am sorry to hear about your connection issues.
Please can I just check if the advice above has helped you out or not? Thanks
Matt - Forum Team
New around here?
