on 29-10-2021 17:41
I have been struggling with random Hub3 reboots now for a little over a month. I can go a few days without a reboot then have 3 in an afternoon. There is no pattern, no local VM work being carried out, no differences in load/connections.
Can someone take a look at the Status reports and see if anything is blindingly wrong.
Channel | Frequency (Hz) | Power (dBmV) | SNR (dB) | Modulation | Channel ID |
1 | 267000000 | -5.2 | 40 | 256 qam | 17 |
2 | 139000000 | -2.4 | 38 | 256 qam | 1 |
3 | 147000000 | -2.2 | 40 | 256 qam | 2 |
4 | 155000000 | -2.7 | 40 | 256 qam | 3 |
5 | 163000000 | -2.9 | 40 | 256 qam | 4 |
6 | 171000000 | -2.4 | 40 | 256 qam | 5 |
7 | 179000000 | -2.7 | 40 | 256 qam | 6 |
8 | 187000000 | -3 | 40 | 256 qam | 7 |
9 | 195000000 | -3.4 | 40 | 256 qam | 8 |
10 | 203000000 | -3.2 | 40 | 256 qam | 9 |
11 | 211000000 | -3.9 | 38 | 256 qam | 10 |
12 | 219000000 | -3.7 | 38 | 256 qam | 11 |
13 | 227000000 | -4.2 | 32 | 256 qam | 12 |
14 | 235000000 | -4.7 | 38 | 256 qam | 13 |
15 | 243000000 | -5 | 40 | 256 qam | 14 |
16 | 251000000 | -5 | 38 | 256 qam | 15 |
17 | 259000000 | -5.2 | 38 | 256 qam | 16 |
18 | 275000000 | -4.7 | 38 | 256 qam | 18 |
19 | 283000000 | -5.2 | 38 | 256 qam | 19 |
20 | 291000000 | -4.7 | 40 | 256 qam | 20 |
21 | 299000000 | -4.5 | 38 | 256 qam | 21 |
22 | 307000000 | -4.4 | 40 | 256 qam | 22 |
23 | 315000000 | -4.5 | 38 | 256 qam | 23 |
24 | 323000000 | -4.2 | 40 | 256 qam | 24 |
Channel | Locked Status | RxMER (dB) | Pre RS Errors | Post RS Errors |
1 | Locked | 40.9 | 40 | 0 |
2 | Locked | 38.9 | 267050 | 17 |
3 | Locked | 40.3 | 436 | 0 |
4 | Locked | 40.3 | 367 | 0 |
5 | Locked | 40.3 | 189 | 0 |
6 | Locked | 40.3 | 291 | 1 |
7 | Locked | 40.9 | 242 | 2 |
8 | Locked | 40.3 | 125 | 0 |
9 | Locked | 40.3 | 64 | 0 |
10 | Locked | 40.3 | 32 | 0 |
11 | Locked | 38.9 | 40 | 0 |
12 | Locked | 38.9 | 55 | 0 |
13 | Locked | 32.3 | 12980575 | 997791 |
14 | Locked | 38.9 | 105 | 0 |
15 | Locked | 40.3 | 86 | 0 |
16 | Locked | 38.9 | 67 | 0 |
17 | Locked | 38.6 | 64 | 0 |
18 | Locked | 38.9 | 31 | 0 |
19 | Locked | 38.9 | 32 | 0 |
20 | Locked | 40.3 | 34 | 0 |
21 | Locked | 38.9 | 30 | 0 |
22 | Locked | 40.3 | 26 | 0 |
23 | Locked | 38.9 | 17 | 0 |
24 | Locked | 40.3 | 34 | 0 |
Time | Priority | Description |
29/10/2021 16:19:56 | Warning! | RCS Partial Service;CM-MAC=***;CMTS-MAC=***;CM-QOS=1.1;CM-VER=3.0; |
29/10/2021 16:19:43 | notice | LAN login Success;CM-MAC=***;CMTS-MAC=***;CM-QOS=1.1;CM-VER=3.0; |
29/10/2021 16:19:31 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=***;CMTS-MAC=***;CM-QOS=1.1;CM-VER=3.0; |
29/10/2021 15:49:55 | Warning! | RCS Partial Service;CM-MAC=***;CMTS-MAC=***;CM-QOS=1.1;CM-VER=3.0; |
29/10/2021 15:49:55 | critical | No Ranging Response received - T3 time-out;CM-MAC=***;CMTS-MAC=***;CM-QOS=1.1;CM-VER=3.0; |
29/10/2021 15:45:24 | Warning! | RCS Partial Service;CM-MAC=***;CMTS-MAC=***;CM-QOS=1.1;CM-VER=3.0; |
29/10/2021 15:45:24 | Warning! | Lost MDD Timeout;CM-MAC=***;CMTS-MAC=***;CM-QOS=1.1;CM-VER=3.0; |
29/10/2021 15:42:17 | Warning! | RCS Partial Service;CM-MAC=***;CMTS-MAC=***;CM-QOS=1.1;CM-VER=3.0; |
29/10/2021 15:42:16 | Warning! | Lost MDD Timeout;CM-MAC=***;CMTS-MAC=***;CM-QOS=1.1;CM-VER=3.0; |
29/10/2021 15:18:23 | Warning! | RCS Partial Service;CM-MAC=***;CMTS-MAC=***;CM-QOS=1.1;CM-VER=3.0; |
29/10/2021 15:18:23 | Warning! | Lost MDD Timeout;CM-MAC=***;CMTS-MAC=***;CM-QOS=1.1;CM-VER=3.0; |
29/10/2021 14:56:59 | Warning! | RCS Partial Service;CM-MAC=***;CMTS-MAC=***;CM-QOS=1.1;CM-VER=3.0; |
29/10/2021 14:56:58 | Error | DCC rejected authentication failure;CM-MAC=***;CMTS-MAC=***;CM-QOS=1.1;CM-VER=3.0; |
29/10/2021 13:50:33 | Warning! | RCS Partial Service;CM-MAC=***;CMTS-MAC=***;CM-QOS=1.1;CM-VER=3.0; |
29/10/2021 13:49:10 | Warning! | Lost MDD Timeout;CM-MAC=***;CMTS-MAC=***;CM-QOS=1.1;CM-VER=3.0; |
29/10/2021 12:50:21 | Warning! | RCS Partial Service;CM-MAC=***;CMTS-MAC=***;CM-QOS=1.1;CM-VER=3.0; |
29/10/2021 12:50:21 | Warning! | Lost MDD Timeout;CM-MAC=***;CMTS-MAC=***;CM-QOS=1.1;CM-VER=3.0; |
29/10/2021 12:26:15 | Warning! | RCS Partial Service;CM-MAC=***;CMTS-MAC=***;CM-QOS=1.1;CM-VER=3.0; |
29/10/2021 12:26:14 | Warning! | Lost MDD Timeout;CM-MAC=***;CMTS-MAC=***;CM-QOS=1.1;CM-VER=3.0; |
29/10/2021 12:20:57 | Warning! | RCS Partial Service;CM-MAC=***;CMTS-MAC=***;CM-QOS=1.1;CM-VER=3.0; |
MAC Details masked
Thanks In Advance.
PS
Trying here first as my interaction with the 'call centres in India' have been far from helpfull in the past
on 29-10-2021 18:45
on 29-10-2021 22:32
As requested
1 | 39399969 | 50.5 | 5120 | 64 qam | 2 |
2 | 25799993 | 49 | 5120 | 64 qam | 4 |
3 | 32600004 | 50.5 | 5120 | 64 qam | 3 |
4 | 46200007 | 50.5 | 5120 | 64 qam | 1 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
on 30-10-2021 19:39
on 02-11-2021 11:41
Hello IanLodge
Sorry to hear of the Hub 3 issues but we appreciate you taking the time to raise this via the forums.
Were you able to complete the Hub pinhole reset? If so, did this resolve the issue at all?
Rob
on 04-11-2021 09:22
I was able to complete a Pin Reset and still getting drop outs.
It is really strange as it can go a week without a drop and then 3 in an hour all whilst the usage has not changed.
on 06-11-2021 11:26
Hi IanLodge, thanks for the reply. Can you do a reboot please as the hub has not been rebooted for 7 days. Once done please forget all devices and then connect only one to see if you are getting the same issue. Can you confirm if the hub is in an open area or is it in a cupboard? ^Chris
