on 23-11-2021 21:38
For at least a month now I've been having random connection drops. Usually happens for a few days then it's fine for a few more. The last three days have been especially bad. Hub is in modem mode connected to a netgear nighthawk R7000. Took that out of the equation today and reverted the hub to router mode but it made no difference. Back to modem mode now.
1 | 475000000 | -2.9 | 38 | 256 qam | 9 |
2 | 483000000 | -2.7 | 38 | 256 qam | 10 |
3 | 491000000 | -2.7 | 38 | 256 qam | 11 |
4 | 499000000 | -2.7 | 38 | 256 qam | 12 |
5 | 507000000 | -3 | 38 | 256 qam | 13 |
6 | 515000000 | -3.2 | 38 | 256 qam | 14 |
7 | 523000000 | -3.5 | 38 | 256 qam | 15 |
8 | 531000000 | -3.2 | 38 | 256 qam | 16 |
9 | 539000000 | -3.2 | 38 | 256 qam | 17 |
10 | 547000000 | -3.4 | 38 | 256 qam | 18 |
11 | 555000000 | -3.7 | 38 | 256 qam | 19 |
12 | 563000000 | -3.7 | 38 | 256 qam | 20 |
13 | 571000000 | -3.7 | 38 | 256 qam | 21 |
14 | 579000000 | -3.5 | 38 | 256 qam | 22 |
15 | 587000000 | -3.2 | 38 | 256 qam | 23 |
16 | 595000000 | -3 | 38 | 256 qam | 24 |
17 | 603000000 | -3.2 | 38 | 256 qam | 25 |
18 | 611000000 | -3.4 | 38 | 256 qam | 26 |
19 | 619000000 | -3.9 | 38 | 256 qam | 27 |
20 | 627000000 | -4.2 | 38 | 256 qam | 28 |
21 | 635000000 | -3.5 | 38 | 256 qam | 29 |
22 | 643000000 | -3 | 38 | 256 qam | 30 |
23 | 651000000 | -2.4 | 38 | 256 qam | 31 |
24 | 659000000 | -2.9 | 38 | 256 qam | 32 |
1 | Locked | 38.6 | 30373 | 106338 |
2 | Locked | 38.6 | 30478 | 110767 |
3 | Locked | 38.6 | 31237 | 115701 |
4 | Locked | 38.9 | 31963 | 122507 |
5 | Locked | 38.9 | 30364 | 117670 |
6 | Locked | 38.9 | 30898 | 129048 |
7 | Locked | 38.6 | 31515 | 127703 |
8 | Locked | 38.9 | 29869 | 110928 |
9 | Locked | 38.9 | 30111 | 116344 |
10 | Locked | 38.6 | 30186 | 127038 |
11 | Locked | 38.6 | 28737 | 134541 |
12 | Locked | 38.6 | 30579 | 178572 |
13 | Locked | 38.9 | 32018 | 178506 |
14 | Locked | 38.6 | 32265 | 194497 |
15 | Locked | 38.9 | 32244 | 189995 |
16 | Locked | 38.9 | 31079 | 179226 |
17 | Locked | 38.9 | 33353 | 202079 |
18 | Locked | 38.9 | 33454 | 209065 |
19 | Locked | 38.9 | 33338 | 226236 |
20 | Locked | 38.9 | 34342 | 224889 |
21 | Locked | 38.6 | 33856 | 235666 |
22 | Locked | 38.6 | 34142 | 230065 |
23 | Locked | 38.9 | 34993 | 223915 |
24 | Locked | 38.9 | 35174 | 232560 |
1 | 39400000 | 47 | 5120 | 64 qam | 4 |
2 | 60299980 | 49 | 5120 | 32 qam | 1 |
3 | 53700000 | 48.5 | 5120 | 32 qam | 2 |
4 | 46200000 | 47.8 | 5120 | 32 qam | 3 |
on 23-11-2021 21:39
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
23/11/2021 21:03:51 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/11/2021 21:03:51 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/11/2021 21:03:49 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/11/2021 21:03:49 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/11/2021 21:03:48 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/11/2021 21:03:48 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/11/2021 21:03:30 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/11/2021 21:03:30 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/11/2021 20:41:6 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/11/2021 20:41:6 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/11/2021 20:38:3 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/11/2021 20:38:3 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/11/2021 20:33:49 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/11/2021 20:33:49 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/11/2021 20:22:43 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/11/2021 20:16:29 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/11/2021 20:16:29 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/11/2021 20:08:47 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/11/2021 20:08:47 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/11/2021 20:07:56 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 23-11-2021 21:40
Live BQM here:
Some BQM highlights from the last 3 weeks:
And on a day its fine it mostly looks like this:
Any help would be greatly appreciated.
on 24-11-2021 15:26
on 24-11-2021 18:40
OK so have unplugged the hub entirely, left unplugged for 5 minutes. rechecked all connections, no kinks or chafing at all. Plugged everything back in and it's still dropping randomly. BQM looks the same as always.
Today had a few 'hiccups' where the connection would drop for maybe a second causing streaming video to pause and online gaming to kick me but then it would come back right away. As of 18:30 its hard dropping again. Dropping connection for up to a minute then it coming back. Then it randomly going any amount of time later again. If yesterday is anything to go by it will be like this for 2 hours now.
There is only 1 ethernet cable plugged directly into the superhub. It's the cable to my router - hub in modem mode. I do have a lot of ethernet devices plugged into the router and another switch I run however. In total 3 game consoles, 1 TV, 2 PC's, 1 laptop and 1 nvidia shield.
Here is the latest network log and upstream data:
24/11/2021 18:38:40 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/11/2021 18:38:40 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/11/2021 18:38:25 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/11/2021 18:38:25 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/11/2021 18:38:23 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/11/2021 18:38:23 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/11/2021 18:38:21 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/11/2021 18:38:21 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/11/2021 18:38:20 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/11/2021 18:38:20 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/11/2021 18:38:16 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/11/2021 18:38:16 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/11/2021 18:31:8 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/11/2021 18:31:8 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/11/2021 18:30:57 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/11/2021 18:30:57 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/11/2021 18:30:36 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/11/2021 18:30:36 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/11/2021 18:29:22 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/11/2021 18:29:22 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
2 | 60300000 | 49 | 5120 | 32 qam | 1 |
3 | 53700000 | 48.5 | 5120 | 64 qam | 2 |
4 | 46200000 | 47.5 | 5120 | 32 qam | 3 |
on 25-11-2021 08:54
on 25-11-2021 09:24
Totally forgot to check that yesterday. My bad. But yep still there.
1 | 475000000 | -2.7 | 38 | 256 qam | 9 |
3 | 491000000 | -2.5 | 38 | 256 qam | 11 |
4 | 499000000 | -2.5 | 38 | 256 qam | 12 |
5 | 507000000 | -2.9 | 38 | 256 qam | 13 |
8 | 531000000 | -3 | 38 | 256 qam | 16 |
12 | 563000000 | -3.5 | 38 | 256 qam | 20 |
17 | 603000000 | -3 | 38 | 256 qam | 25 |
18 | 611000000 | -3.2 | 38 | 256 qam | 26 |
19 | 619000000 | -3.7 | 38 | 256 qam | 27 |
20 | 627000000 | -4 | 38 | 256 qam | 28 |
22 | 643000000 | -2.7 | 38 | 256 qam | 30 |
23 | 651000000 | -2.2 | 38 | 256 qam | 31 |
1 | Locked | 38.9 | 5187 | 67889 |
2 | Locked | 38.6 | 5418 | 69287 |
3 | Locked | 38.9 | 5730 | 67234 |
4 | Locked | 38.6 | 6101 | 75759 |
5 | Locked | 38.6 | 6694 | 91513 |
6 | Locked | 38.6 | 5701 | 81555 |
7 | Locked | 38.9 | 4080 | 58873 |
8 | Locked | 38.9 | 4465 | 84984 |
9 | Locked | 38.9 | 4096 | 96682 |
10 | Locked | 38.6 | 4065 | 108317 |
11 | Locked | 38.6 | 4084 | 104516 |
12 | Locked | 38.9 | 4111 | 102152 |
13 | Locked | 38.6 | 4426 | 115355 |
14 | Locked | 38.9 | 4948 | 122501 |
15 | Locked | 38.6 | 5380 | 121935 |
16 | Locked | 38.6 | 5138 | 128444 |
17 | Locked | 38.9 | 5099 | 128290 |
18 | Locked | 38.9 | 5250 | 131541 |
19 | Locked | 38.6 | 5679 | 130005 |
20 | Locked | 38.6 | 5346 | 126320 |
21 | Locked | 38.6 | 6115 | 160462 |
22 | Locked | 38.6 | 6287 | 154455 |
23 | Locked | 38.6 | 6400 | 142678 |
24 | Locked | 38.9 | 6382 | 147073 |
Guessing this is a technician job at this point?
on 25-11-2021 09:27
on 25-11-2021 13:26
on 25-11-2021 14:18
I've managed to book an engineer visit for tomorrow. Took a couple phone calls three hours apart. First guy got me to reset the superhub with the pin hole button but it then proceeded to be awful for the next three hours dropping 10+ times.
Next phone call they took my superhub out of modem mode for some reason despite me saying I'd tried that already. But they did eventually book me an appointment. Funnily enough since I came back out of modem mode that time the PostRS errors are now 0. Upstream qam is still acting up however.
Hopefully all will be good after the engineer. Will update thread if it's resolved.
