on 01-04-2022 16:24
THE GREEN LIGHT HAS TURNED RED AND HAS BEEN LIKE THIS FOR A FEW WEEKS.
on 01-04-2022 16:30
Red light is overheat warning. Is the Hub hot ? Do a pinhole reset and if the light remains red, you need to press VM for a replacement Hub.
on 01-04-2022 18:46
01-04-2022 19:00 - edited 01-04-2022 19:01
Kind of vague OP, what model HUB as RED is overheating on the 3 but not on the 4?
on 04-04-2022 08:59
Hey @doh705,
Welcome back to the community and thanks for taking the time to post.
I'm sorry to hear of the issues that you're having at the moment with your hub, I have checked our system and can see that you currently have a hub 3 and red light means over heating, we would need to replace your hub via technician visit.
I can arrange the appointment from here but would need to confirm a few details via a private message, that I will drop over in a moment.
Please look out for the private message and we can get started.
Regards,
Steven_L
on 05-04-2022 11:23
Thanks for confirming your details @doh705.
I have arranged for the appointment and you can track your engineer appointments online. Simply sign in to My Virgin Media and you’ll see your appointments on your account dashboard.
Regards,
Steven_L
