Quick start broadband not working
cmd1980
Just moved and  replaced a previously owned router that was working with a hub 5 that now doesn’t work . Called and it said that quick start equip is activated and auto hangs up. Found a way of speaking to someone who says sometimes you have to wait 24 hrs ? Is that right ? Router sets up 5.0 with flashing blue light then solid white . Can connect to router but says no internet. Hit reset at bottom . Switched off for ten minutes .Still no internet  Has this happened to anyone else ? Am I being impatient ?
1 ACCEPTED SOLUTION
Accepted Solutions
It could also be disconnected in the street cabinet. Sounds like you need a technician to check.
4 REPLIES 4
Hi @cmd1980
Looking through today's posts it appears that VM activations aren't currently working.
Hopefully the VM systems will kick in fully tomorrow and complete the activation, however if doesn't, then call the activation team on 0800 953 9500 to activate the hub
Dave
The do's and don'ts.
cmd1980
The Internet switched on around 11pm after another router turn off and on for 10 mins. They did say their systems were down so very relieved its now working. Was strange as the white light was on so it showed internet on the line. Lets hope it holds now.
Yayyy.
Thanks for updating the thread @cmd1980
Fingers crossed you have no further problems, but if you do just holler.
Dave
