  • 86
  • 6
Quick question re Hub3 in Modem Mode
I have just replaced a Superhub1 with a Hub3 in modem mode. The system is working well but the Base Light is steady red, is this normal? If so:
Why don't they tell you in the setup instructions? I waited for much more than the prescribed 5 min before risking attaching my router and finding that everything appeared to be working.
What happens in an error condition?
Tags (2)
  • 2.2K
  • 163
  • 290
Dialled in
Re: Quick question re Hub3 in Modem Mode
Magenta = Modem Mode
Red = Overheating
There isn't much difference between the two!
  • 86
  • 6
Thanks, Carl.
Even less difference with my kind of colourblindness, I suspect!
  • 1.56K
  • 78
  • 158
Hi Dark_Fiber
Please can you confirm everything is resolved now?
And thanks @carl_pearce for your help:-)
Lee_R
  • 86
  • 6
Hi Lee, thank you for your concern. I thought marking Carl's response as a Helpful Answer would close the matter.
Since you prod me 🙂 I must reiterate:
I haven't seen mention anywhere of the Base LED being purple/magenta in Modem Mode. As I for one can't see a difference from red, it seems a crazy choice to have made- I waited a long time thinking there was a temporary "error condition" while the hub was changing mode.
Secondly, is overheating the only fault condition that the Hub3 can indicate when in MM?
[As it happens I have an engineer visit booked for tomorrow for what telephone support called an "intermittent connection" (my new modem has not yet exceeded 7h40 uptime). However, I believe this fault to lie outside the premises.]
  • 1.56K
  • 78
  • 158
Thanks for getting back to me Dark_Fiber
The tech visit should be able to shed some light and I'm confident will resolve your issues.  I've not looked at your hub remotely so I cannot tell if there's anything to suggest there's an external issue.
Lee
