  • 7
grgarg
Qualcomm Atheros WiFi PIR Camera
I have just purchased a Spy Camera PIR CCTV which will not connect to Virgin Super Hub 2ac router. The camera company states that the network card's IP is 192.168.1.1 whereas the Virgin router is 192.168.0.1 so that the camera will never connect. Has anyone any idea to resolve this problem?
  • 19.23K
  • 1.68K
  • 4.22K
Re: Qualcomm Atheros WiFi PIR Camera
whats the exact model, since you can't change the default gateway from 0.1 to 1.1, should be able to change the IP address scheme on the camera or change the subnet.
If someone's helped you out say thanks by clicking on the thumbs up on kudos. If someone's solved your problem, why not mark their message as an Accepted Solution, but only do this once issue has been resolved.
