on 10-05-2022 07:11
I have not been able to connect my ps4 to WiFi for years and each and every time you get into a forced re start of your router by Virgin media it causes even more problems even with it connected via an ethernet cable
I used to have an extra 10 pound charge on my account which would help you if you had any technical issues and had no problems with connecting via WiFi all around the home a few years ago I removed this extra charge of my account and very shortly after doing this I started getting huge problems with connecting via WiFi and its never been the same since
My frustration with the router and the many problems it causes including never being able to connect via WiFi to my sky Q box which also started after removing this extra charge is this virgih media forcefully doing this to get extra money out of people ?
on 10-05-2022 09:20
What did this extra £10 cover or include?
Sorry and excuse my ignorance but I don't understand?
Was there an extra 'booster' or extra equipment? Did you have a faster broadband speed? Extra support?
Also, what hub do you have? What checks and tests have you done?
on 10-05-2022 14:08
The 10 pounds covered insurance which I was told to pay when this first happened years ago to help eliminate the problem by a virgin colleague while with insurance the problem was never there shortly after stopping my insurance the problem came back and has been on and off for years
My sky Q box has not connected to my hub 3 for years even though I had a sky engineer to look at it the hub 3 is now connected to a sky router box to get it to connect to the hub even the engineer found it impossible to connect
What have I tried if virgin was to pay me a wage for everything I have tried I would be a millionaire ie resetting loads of times turning it on and off moving it from room to room different cables you name it I have tried it on excessive amount of times over the years
on 10-05-2022 14:30
on 10-05-2022 14:41
It's a hub 3.0
I believe its connecting to 2.4 ghz
My phone and tablet have never had a problem connecting its always been with ps4 and sky since moving to my new address 14 months ago the same problem has come with me I can no longer have my ps4 in my bedroom I have to connect via ethernet cable in the room
Sometimes I have connected my ps4 to WiFi but this involves up to 1 hour of messing around setting up the Internet connection
on 10-05-2022 15:02
on 12-05-2022 15:18
Hi stevenleader,
Thanks for your post and welcome to the community.
Apologies for the issues faced with the service, may I ask is the PS4 within the same room as the Hub?
From checking our system here, everything seems to be in spec.
Is that the only device facing issues?
on 12-05-2022 15:39
Splitting the SSIDs as suggested above should help.
Re the insurance it sounds like Gadget Rescue. If it is and you still have it I suggest you cancel it as it will rarely be good value.
https://www.virginmedia.com/help/security/gadget-rescue
