  • 10
Igzilla
Message 1 of 15
Problems with Hub 3.0
My hub is all over the place. We have 3 mobile phones, 3 laptops, a kindle and a Network streamer that should be connecting via wifi and a hard drive that's connected via ethernet cable. Currently, only 1 laptop is connected with internet access, all the phone can connect to wifi but haven't got internet access, the Network Streamer can see the network but can't connect at all and the ethernet cable connected hard drive isn't showing up either. Problems been happening now for a few days. Any help or advice gratefully received. Here's some logs:
1234750000-1.538256 qam13
2322750000-0.538256 qam24
3314750000-0.738256 qam23
4306750000-0.738256 qam22
5298750000-0.738256 qam21
6290750000-138256 qam20
7282750000-140256 qam19
8274750000-1.438256 qam18
9266750000-1.238256 qam17
10258750000-1.438256 qam16
11250750000-1.540256 qam15
12242750000-1.738256 qam14
13226750000-1.538256 qam12
14218750000-1.438256 qam11
15210750000-1.438256 qam10
16202750000-1.238256 qam9
17194750000-140256 qam8
18186750000-0.738256 qam7
19178750000-0.740256 qam6
20170750000-0.740256 qam5
21162750000-0.740256 qam4
22154750000-0.938256 qam3
23146750000-0.540256 qam2
24138750000-0.538256 qam1
1Locked38.92430
2Locked38.97210
3Locked38.96580
4Locked38.95410
5Locked38.65790
6Locked38.94570
7Locked40.33790
8Locked38.94130
9Locked38.93450
10Locked38.93190
11Locked40.33080
12Locked38.92700
13Locked38.92170
14Locked39.31870
15Locked38.91550
16Locked38.91320
17Locked40.3880
18Locked38.91010
19Locked40.3860
20Locked40.3600
21Locked40.3550
22Locked38.9310
23Locked40.3240
24Locked38.6180
14580000040.3512064 qam1
23580000041512064 qam2
32740000040.8512064 qam3
45370000040.8512064 qam4
3ATDMA0000
4ATDMA0000
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
Vee7a9a364ea87600.cm
SFID11752
Max Traffic Rate172500000
Max Traffic Burst42600
Min Traffic Rate0
  • 10
Igzilla
Message 2 of 15
Re: Problems with Hub 3.0
SFID11752
Min Traffic Rate0
Network LogTime Priority Description
2018-11-27 20:14:12.00Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-11-27 20:14:12.00criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-11-29 00:19:42.00criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-11-29 07:41:09.00Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-11-29 08:45:17.00ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-11-29 14:41:36.00Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-11-29 18:35:55.00ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-11-30 04:26:36.00ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-11-30 06:17:53.00criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-11-30 11:38:07.00Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-11-30 11:38:08.00criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-11-30 11:38:08.00Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-11-30 11:38:13.00Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-11-30 11:40:27.00criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:04:06.00criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-11-30 15:57:25.00Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-11-30 17:26:42.00criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-11-30 23:39:29.00Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2018-12-02 13:22:40.00criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 8
Gyro85
Message 3 of 15
Watching with interest mine has just started with identical issue, will be calling tomorrow
  • 10
Igzilla
Message 4 of 15
I did initially call VM last Friday as I lost the lot, internet and TV for about 90 mins, but then it all came back, so I foolishly cancelled the engineer appointment...
  • 21.83K
  • 626
  • 3.66K
Sephiroth
Message 5 of 15
WiFi is a huge problem. Have you read my sticky post in this section of the forum?
https://community.virginmedia.com/t5/Networking-and-WiFi/UNDERSTANDING-KEY-ASPECTS-OF-WiFi/td-p/3870...
Have a read and let us know if any of that applies to your case?
  • 10
Igzilla
Message 6 of 15
Thanks, but not really helpful. The hub hasn't moved, was working fine until last Friday and there has been no changes around the house in terms of walls, furniture etc etc to interfere with the signal strength. The fact that you can be in the same room as the hub, connected to the wifi but still have no internet access is surely evidence that the hub is malfunctioning in some way? And why is the appearance of devices connected by ethernet cable to the hub so erratic?
  • 6K
  • 460
  • 1K
Hero
Message 7 of 15
One thing that can affect WiFi, especially when all has been good for sometime, is that inteference has started being generated. This could be in the form of neighbours getting new WiFi, of perhaps even some new electrical equipment that is generating the interference.
  • 21.83K
  • 626
  • 3.66K
Sephiroth
Message 8 of 15
There is evidence in the log suggesting that the circuit may have dropped on a few occasions.
This is now for the VM bods to delve into. They take a week or so to get to a thread.
  • 15.2K
  • 653
  • 32
Moderator (Retired) John_G
Moderator (Retired)
Message 9 of 15
Hi Igzilla,
Sorry to hear you've had some problems. I've just checked your connection and can see no issues from here. Your power levels, SNR and area contention are healthy.
How is your connection now?
  • 10
Igzilla
Message 10 of 15
Thanks, it's been behaving itself since Sunday evening, though I have had one further warning in the log of RCS partial service:
2018-12-05 08:35:52.00Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
