  • 11
Shepsie
Message 1 of 10
Problems connecting to Discord and Other Games
Hello,
Since this morning have been experiencing slower internet than normal and certain gaming related websites are no longer working unless I use a VPN.
The website https://discordapp.com/ wont load or the app wont work  either but when a a VPN is turned on it connects no problems.
An example of another gaming website also doesn't work escapefromtarkov.gamepedia.com
Vivid 350 Super Hub 3 (Modem Mode) - Edgerouter X and PC connected via Ethernet.
Tried the below with no success.
- Superhub 3 in router mode with direct connection.
- Connecting to the website via the IP.
- Router reset to factory default and setup again.
- AV and Firewall paused.
- Rang support who did line test with no problems.
- DNS set to google DNS.
- Tried the website on another PC on wired and a Phone on wireless.
Any help for a solution is much appreciated as I had no problems for the last year of service.
  • 8.58K
  • 879
  • 1.33K
Message 2 of 10
Re: Problems connecting to Discord and Other Games
It looks like your Hub's IP address in router mode is blocked. If you put it into modem mode it will assign a new IP - see if that connects. If it does then you need to find out why you IP is blocked on the gaming websites
  • 11
Shepsie
Message 3 of 10
Tried already going from Modem Mode to Router Mode and back and no changes.
  • 4.44K
  • 297
  • 742
Roger_Gooner
Community elder
Message 4 of 10
I'm getting access to both sites.
C:\>tracert discordapp.com
Tracing route to discordapp.com [104.16.59.5]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  192.168.1.1
  2     *        *        *     Request timed out.
  3     9 ms    10 ms     8 ms  haye-core-2a-xe-233-0.network.virginmedia.net [62.253.8.121]
  4     *        *        *     Request timed out.
  5    11 ms    10 ms    11 ms  tele-ic-7-ae2-0.network.virginmedia.net [62.253.175.34]
  6     9 ms     9 ms     9 ms  2-14-250-212.static.virginm.net [212.250.14.2]
  7     9 ms     9 ms     8 ms  104.16.59.5
Trace complete.
C:\>tracert escapefromtarkov.gamepedia.com
Tracing route to escapefromtarkov.gamepedia.com [104.17.94.92]
  3    10 ms    10 ms    11 ms  haye-core-2a-xe-233-0.network.virginmedia.net [62.253.8.121]
  5    12 ms    10 ms     9 ms  tele-ic-7-ae2-0.network.virginmedia.net [62.253.175.34]
  7    10 ms     9 ms     8 ms  104.17.94.92
Trace complete.
C:\>
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 8.58K
  • 879
  • 1.33K
Message 5 of 10
Maybe both are blocked - they are semi-permanent - you will get the same ones back if you toggle between modes.  See if they have been blocked.
  • 11
Shepsie
Message 6 of 10
This has now been updated on the site, so hopefully resolved my problems once fixed.A493AB76-3BFD-4A3B-9AF7-852356E6FDB8.png
  • 11
Shepsie
Message 7 of 10
Issue in area was fixed and didn't help the problem, got through to 2nd line who performed lots of test to no avail and not able to send out engineer even after emailing screenshots of failed pings and webpages not loading from phone on wifi or Pc on ethernet.
Have been advised will need to wait 5 working days and now the VPN wont even connect.
Any suggestion to help will be greatly appreciated.
  • 14.59K
  • 432
  • 46
Moderator (Retired) Ralph_R
Moderator (Retired)
Message 8 of 10
Hi Shepsie,
Could you check that both Virus Safe and Web Safe options are disabled in My Virgin Media and then retest.
If access is still restricted it would be helpful if you could post trace routes to the blocked sites.
Ralph_R
Forum Moderator
  • 11
Shepsie
Message 9 of 10
After I posted this around 2-3 issues reported in local area and then issue got resolved whe the issues were fixed.
Annoying I wasted so much time on the phone and diagnosing my own equipment.
  • 1.03K
  • 48
  • 91
Moderator
Moderator
Message 10 of 10
Hi Shepsie,
Thanks for your post.
Apologies for any frustration or inconvenience caused by this.
How are things with your services now?
If you need any help, please let us know and we will be more than happy to look into things for you.
Lindsey_C
