Problems accessing router
PAPA-ROCK
Hi I have a hub 3 and can't access it on line, I have followed the steps by typing in 192.168.0.1, I need to change it to 2.4GHz so I can operate my cctv cameras. Is my hub out of date and needing replaced?
1 ACCEPTED SOLUTION
Accepted Solutions
Straight6Petrol
Dialled in
Remember modem mode replaces 192.168.0.1 with 192.168.100.1, worth giving that a shot also.
Are you using a phone to access the settings? Sometimes shutting off data (3g/4g/5g) forces the phone to connect over WiFi which is what you want.
Finally, if you have a laptop/desktop, try the address again over ethernet. If all this doesn't work, worth trying a pin hole reset.
3 REPLIES 3
What does the web browser give you? You could try pin hole reset of the hub.
Straight6Petrol
Dialled in
Thanks that solved the problem
