  • 13
mabdul
Message 1 of 12
Pre rs errors and post rs errors again engineer visit
Getting a lot of pre rs errors and post rs errors. Did have an engineer out last week. And he moved me to different tap bank as my downstream power (dBmV) was getting close to 10 on a few channels. He also installed an isolator to the coax coming into the house.
I've just rebooted my superhub 3 which is in modem mode to see if it helps but as soon as it boots up there is pre rs errors, no post just yet. I get there may some errors on the line as no network is perfect. Hub was online for 4 days no reboots and errors both pre and post were in the thousands. No screen shot of this as i've rebooted the router now.
Stats below which all seem fine to me nothing too high or low
1299000000437256 qam21
21390000008.538256 qam1
31470000008.138256 qam2
41550000007.837256 qam3
51630000007.438256 qam4
61710000007.338256 qam5
7179000000738256 qam6
81870000006.838256 qam7
91950000006.538256 qam8
102030000006.138256 qam9
11211000000637256 qam10
12219000000637256 qam11
132270000005.838256 qam12
142350000005.637256 qam13
152430000005.538256 qam14
162510000005.538256 qam15
172590000005.538256 qam16
182670000005.537256 qam17
192750000005.538256 qam18
202830000005.338256 qam19
212910000004.837256 qam20
223070000003.537256 qam22
233150000004.438256 qam23
24323000000538256 qam24
1Locked37.360
2Locked38.600
3Locked38.9180
4Locked38.660
5Locked38.950
6Locked38.650
7Locked38.6160
8Locked38.660
9Locked38.660
10Locked38.650
11Locked37.640
12Locked37.650
13Locked38.650
14Locked38.650
15Locked38.950
16Locked38.600
17Locked38.650
18Locked37.600
19Locked38.650
20Locked38.650
21Locked37.6130
22Locked37.600
23Locked38.640
24Locked38.660
1394000924512064 qam10
2258000124512064 qam12
3326000144512064 qam11
4461999934512064 qam9
3ATDMA0000
4ATDMA0000
  • 13
mabdul
Message 2 of 12
Re: Pre rs errors and post rs errors again engineer visit
Video calls get a lot dropped frames or complete disconnections and online gaming is suffering from disconnections and lag.
  • 1.02K
  • 58
  • 93
Message 3 of 12
Hi there mabdul,
Thanks for your post - sorry to understand that you're having some issues so soon after the technician visit.
You advise that your using the HUB3 in modem mode - are you having the same issue when not in Modem mode?
Cheers
Katie - Forum Team
  • 7.31K
  • 761
  • 1.14K
Legend
Message 4 of 12
post up your network logs as well.
  • 13
mabdul
Message 5 of 12
I have turned on modem mode now, to rule out my 3rd party router being an issue. Network logs also below. Still getting errors upon boot up. Before restarting channels 7 & 8 had pre rs errors in the 10,000s reset were a few hundred with a few post errors. Have been booted up for 5 mins now. Have been speaking to live chat who end up going on a break and then disconnecting me. Making me go through the explanation again. They're are having me do speed tests when speed isn't an issue its the random amount of errors.
1299000000-0.437256 qam21
21390000004.538256 qam1
31470000004.138256 qam2
41550000003.737256 qam3
51630000003.437256 qam4
61710000003.237256 qam5
7179000000337256 qam6
8187000000337256 qam7
91950000002.738256 qam8
102030000002.537256 qam9
112110000002.437256 qam10
122190000002.436256 qam11
132270000002.237256 qam12
14235000000237256 qam13
15243000000237256 qam14
162510000001.937256 qam15
172590000001.737256 qam16
182670000001.537256 qam17
192750000001.538256 qam18
20283000000137256 qam19
212910000000.537256 qam20
22307000000-0.537256 qam22
233150000000.237256 qam23
243230000000.938256 qam24
1Locked37.370
2Locked38.600
3Locked38.650
4Locked37.650
5Locked37.630
6Locked37.600
7Locked37.640
8Locked37.640
9Locked38.650
10Locked37.660
11Locked37.660
12Locked36.350
13Locked37.660
14Locked37.660
15Locked37.350
16Locked37.600
17Locked37.650
18Locked37.600
19Locked38.660
20Locked37.6120
21Locked37.370
22Locked37.600
23Locked37.640
24Locked38.650
  • 13
mabdul
Message 6 of 12
1393999764.35512064 qam10
2258000144.35512032 qam12
3325999694.35512064 qam11
4461999394.35512064 qam9
3ATDMA0000
4ATDMA0000
  • 13
mabdul
Message 7 of 12
  • 13
mabdul
Message 8 of 12
13/06/2019 20:52:41criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=CMTS-MAC=CM-QOS=1.1;CM-VER=3.0;
13/06/2019 20:52:41Warning!RCS Partial Service;CM-MAC=CMTS-MAC=CM-QOS=1.1;CM-VER=3.0;
13/06/2019 20:52:46Warning!Lost MDD Timeout;CM-MAC=CMTS-MAC=CM-QOS=1.1;CM-VER=3.0;
13/06/2019 20:53:36criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=CMTS-MAC=CM-QOS=1.1;CM-VER=3.0;
13/06/2019 20:53:57Warning!RCS Partial Service;CM-MAC=CMTS-MAC=CM-QOS=1.1;CM-VER=3.0;
13/06/2019 20:54:0criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=CMTS-MAC=CM-QOS=1.1;CM-VER=3.0;
13/06/2019 20:54:0Warning!RCS Partial Service;CM-MAC=CMTS-MAC=CM-QOS=1.1;CM-VER=3.0;
13/06/2019 20:56:0criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=CMTS-MAC=CM-QOS=1.1;CM-VER=3.0;
14/06/2019 12:08:50criticalNo Ranging Response received - T3 time-out;CM-MAC=CMTS-MAC=CM-QOS=1.1;CM-VER=3.0;
  • 13
mabdul
Message 9 of 12
Just been advised on the phone that there is no issue with my line. They can see that power levels and SNR are fine. Apparently they can't see errors on the line, but don't have a system for me to email them screenshots. Have been in told yesterday that there was an outage in my area, which is a lie because my neighbour who live two doors down from me was online all day yesterday. The advice i've been given now is to factory reset my router to fix the errors and monitor for 24 hours again.
Upon factory reseting
01/01/1970 00:01:26ErrorMissing Mandatory MDD TLV on primary DS Channel;CM-;CMTS-;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:42criticalNo Ranging Response received - T3 time-out;CM-MAC=;CMTS-;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:02:0ErrorMissing Mandatory MDD TLV on primary DS Channel;CM-MAC=;CMTS-;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:02:17criticalNo Ranging Response received - T3 time-out;CM-CMTS-;CM-QOS=1.1;CM-VER=3.0;
  • 13
mabdul
Message 10 of 12
1Locked32.910998613020
2Locked35.7284816862
3Locked35.5519914557
4Locked35.5419115570
5Locked35.7136222244
6Locked35.577799636
7Locked35.793619165
8Locked35878512201
9Locked35.791789687
10Locked3574478861
11Locked34.997199262
12Locked34.4293031771
13Locked34.4178332463
14Locked34.980678967
15Locked34.964058685
16Locked34.920078249
17Locked3521447190
18Locked34.450887303
19Locked34.461706919
20Locked34.3116676961
21Locked33.8228908292
22Locked32.910672716120
23Locked33.42142816587
24Locked33.9902314592
