You may get away with cheaper clip on ferrites on the mains lead of your DJ kit - it depends on the frequency and level - but many of the smaller ferrites are for VHF, not HF where the PLAs operate.
A Fair-Rite 0431177081 ferrite clamp would be best to try - several turns of the power lead through it - they cost around £15 - available on Fleebay and various websites.
Also, see this site on how to use;
https://rsgb.org/main/technical/emc/using-emc-filters-and-ferrites/
Some of the 'mains cleaners' or whatever are not very good, especially at the frequencies in question.
I know a bit about Wi-Fi, Telecoms, and TV as I used to do it for a living but I'm not perfect so don't beat me up... If you make things you make mistakes!
