Power light flashing, no internet
Hi, The power light on our hub 3 is flashing green and there is no internet connection. Was working okay last night. TV still works okay. Have rebooted andcand all cable connections and service status is okay. Help!
  • 3.89K
  • 234
  • 428
Re: Power light flashing, no internet
Hi Shortstumpylegs,
Thanks for reaching out to us in our community and welcome, I am sorry to see you have had no internet due to the router just flashing, as it has been 2 days since your last post are you still having the same issue or has this now been resolved?
I have had a look our end and I can see a couple of your downstream power levels are out, I advise to check all your internal and if possible external connections are hand tight.
Kind regards
Paul.
