Post RS Errors and T3 timeouts
SquidgyB2009
Hi There,
I have noticed some connection issues, slow speeds etc on my broadband so decided to have a look at the Hub3 modem logs to see what was happening, then I noticed this:
1Locked38.9545410760
2Locked37.6506810350
3Locked37.6505710253
4Locked38.6485410271
5Locked37.3640810693
6Locked38.6491410228
7Locked38.6487810483
8Locked38.6491110493
9Locked37.6557210716
10Locked38.6490011597
11Locked38.9489010974
12Locked38.9500110844
13Locked37.6531411879
14Locked38.6556011272
15Locked38.6509911003
16Locked38.6530712548
17Locked37.6552111087
18Locked38.6619211373
19Locked38.6526111006
20Locked38.9516511081
21Locked38.9519911074
22Locked38.6542811081
23Locked38.6554111283
24Locked38.642243674
1ATDMA0030
2
ATDMA0030
3ATDMA0040
4ATDMA0030
5ATDMA0000
6ATDMA0040
Any clues?
6 REPLIES 6
Ashleigh_C
Hi there @SquidgyB2009
I am so sorry that you have experienced these issues with your service and thank you again for you post.
I have taken a look and I cannot see anything on our side that maybe effecting your service, can I ask if you are noticing issues on both wired and WiFi connections?
Too many errors, but the figures are accumulative since the hub was last power cycled. So please turn off your hub for a short period, this will reset the counters, then post a new full set of stats after about two hours. This will indicate the current line status. If they are then high you will need a technician’s visit to rectify.
Sephiroth
Btw, when the modem boots up, it is not in a state of grace because it is receiving gibberish while it is syncing.  There are likely to be post-rs errors.
Hi Sephiroth,
Are you able to confirm if the issues you're having are over a wired or wireless connection? So we can run through further checks.
How have things been since you posted?
Alex_Rm
Hi all,
Thi ks appear to have settled since I posted. I will keep an eye on it and post again if I get other problems.
Thanks all
@Alex_RM wrote:
Hi Sephiroth,
Alex_Rm
I was providing advice to the OP not reporting a problem on my circuit.  I think my post made that clear.
Cheers
