on 07-06-2022 10:59
Trying to set up port forwarding for cctv at home video only lasts for seconds when viewing away from home, at home picture stays.
any ideas?
on 07-06-2022 13:05
I've seen/heard of various issues around port forwarding on the VM and other ISP hubs - one of the reasons I use a third party router with hub in modem mode - that just works...
on 07-06-2022 14:15
"video only lasts for seconds when viewing away from home"
If this is the case then it cannot be port forwarding. If port forwarding was not working, you would get nothing at all.
on 07-06-2022 15:21
cctv nvr make alhua
ports set to 80 TCP
07-06-2022 17:32 - edited 07-06-2022 17:32
Port 80 redirected to a CCTV system is very insecure. Hope it’s got a very good password.
on 07-06-2022 18:28
@Fredkcox1 wrote:Hi
cctv nvr make alhua
I’m guessing you mean Dahua ? - often misspelled as in this link;
https://jimssecurity.com.au/what-is-alhua-cctv/
on 07-06-2022 18:38
I suspect you need port 37777 TCP forwarded
as shown Here and in various other webpages
I would avoid forwarding (therefore exposing) port 80 - it’s only needed for the login/webpage which you can generally avoid for remote access - if you really must use it choose another port at least
I’m not sure why you see a brief bit of video if ports aren’t open though
on 07-06-2022 18:49
Finally, when you check/test remote make sure you use an external internet connection - such as a friends, work, coffee shop or cellular connection - the hub/router may not allow ‘hairpin’ connections.
