DillonR
Port forwarding issues
So I've been trying to port forward @ ranges 7777-7777 however, whenever I test the connection, it never forwards the port, however, this issue seems to be with any port I try forward and the only outgoing ports I seem to be able to have are the defaults of UPnP on the Hub 3.0. Could anyone help with this issue as it was not present a few months ago and I haven't made any changes to hardware or settings on the website and even reset the router to factory settings to make sure it wasn't any settings I overlooked. I am not too familiar about how everything works and only have a general idea about this topic so it may just be a minor issue that's causing inconvenience with servers I hosted in the past.
  • 12.2K
  • 457
  • 1.09K
Re: Port forwarding issues
Maybe you got a firmware update that breaks something.
Many problems with the hub in router mode and is buggy if you need a port forward use the hub in modem mode with your own router with 1Gb ports.
