  • 358
  • 9
  • 39
Superfast
Message 11 of 66
Re: Port Forwarding on Hub 3
@Eseche wrote:
That's exactly the approach I have used.  How did you verify the ports were open?
I attempted an RDP sessions to my IP and it worked.
Make sure your firewall is definitely turned on, as if your setup is the same as mine, I can't think why else it wouldn't be working. When you add them, you are clicking "apply changes" at the very bottom aren't you?
  • 7
Message 12 of 66
Hi all, I too am having problems. I am trying to forward a port on hub 3.0 and not getting anywhere. In summary:
- new VM Hub 3.0 (Arris model)
- in router mode
- have forwarded the port as per image
Ports forwardedPorts forwarded
- Firewall is ON as per image
Firewall settingsFirewall settings
- program is running and listening to the port
- program not using UPnP, but it is enabled in the router
- I have rebooted the hub 3.0
- Port checkers report the port as closed, and programme is not receiving data.
Any ideas?
Tags (2)
  • 6
Message 13 of 66
Hi there
I am having the same issue.
Rule added for Port 80, to IP 192.168.0.200.
Firewall is enabled
Checking using online tool: http://www.portchecktool.com/
Which shows the following:
Problem! I could not see your service on [my IP] on port (80).
Reason: Connection timed out.
Also tried non standard ports.
Any ideas?
  • 70
Message 14 of 66
Unfortunately there is no resolution
One of virgins higher tier techs told me that the new hubs port forwarding does not work.
In order to resolve the issue I downgraded to the AC
Which worked fine.
Also just a quick note it was only common ports that I had issues with 443.80 etc. Rdp on 3389 was fine.
But in all honesty downgrade your router and save all the headaches. I got the router downgrade for free as I was a new customer not sure about your situation
Good luck!
  • 6
Message 15 of 66
Oh I suspected something router related! Many thanks for the reply.
I am a new customer, setup is 2 weeks old. I will contact them now and ask for a new router.. hope the old router is OK otherwise?
  • 70
Message 16 of 66
I see no benefit with the new router over the old tbh.
Handles my vivid200 fine
Wireless is good
Firewall works
Port forwarding works
Decent
  • 7
Message 17 of 66
Well, I eventually got a "new old" router out of them and they sent me a Hub 2. I am still having the same problem, with port checker tools showing port as closed..
  • 6
Message 18 of 66
My broadband is only 100MB so hopefully should be fine.
Just ordered a replacement which should be here in 5 days and can open the ports
  • 6
Message 19 of 66
Did you get the Super hub2.0 AC model which is also having issues?
  • 70
Message 20 of 66
Iv notbhad any issues with 2ac port forwarding works great
