on 18-06-2022 16:03
When port forwarding the IP shows up as 192.168.0.XX when my IP is 192.168.1.XX. How can I fix this?
Thanks in advanced
on 18-06-2022 18:06
on 18-06-2022 18:47
@Ftroup wrote:Hi,
Thanks in advanced
So the device you’re trying to port forward to has a fixed address in the range 192.168.1.XX ?
Change the IP address in the settings for that device.
You can’t change the address range for the VM hub.
Or get your own router as also suggested.
on 20-06-2022 18:54
Hi Ftroup,
Thank you for your post and welcome to the forums 🙂
I am sorry to hear you are having issues with your port forwarding, have you tried the helpful advice from @legacy1 and g0akc? Let us know 🙂
