  • 7
Shellbag29
Message 1 of 10
Poor signal upstairs
My daughter can't use tablets or smart tv in her bedroom, the signal is low and often stops
  • 8.61K
  • 884
  • 1.34K
Message 2 of 10
Re: Poor signal upstairs
What model of hub is her signal meant to come from? Can she connect ok  when near the hub ?
  • 19.23K
  • 1.68K
  • 4.22K
Message 3 of 10
just to add what jbrennand asked, have the wifi worked previous in your daughters bedroom
If someone's helped you out say thanks by clicking on the thumbs up on kudos. If someone's solved your problem, why not mark their message as an Accepted Solution, but only do this once issue has been resolved.
  • 7
Shellbag29
Message 4 of 10
I have hub 3.0.  Her tablet works fine downstairs and even in my bedroom..(above the hub) but her bedroom next door is poor,  even prime movies stops or don't load on her tv.
  • 8.61K
  • 884
  • 1.34K
Message 5 of 10
OK - one thing to try first to clear up the Hub3 wifi, that does help in lots of examples like this is (if you havent already done it)   Go into the Hub3 settings (go to http://192.168.0.1  or  http://192.168.100.1 in your browser) and in "smart wifi" disable the "channel optimisation".  Then, in advanced>wireless>security, rename the 2.4 & 5 GHz network ssid's.  Just change the names to whatever you like and something that will differentiate them - e.g - xxxxx2 & xxxxx5) use the same password  if you like or a new one you will remember,  Then, save settings and restart Hub.  Your 2 wifi networks will now be clearly separated and you can then select the network to connect to individually on each device.  The 5GHz network is usually better and subject to less interference and the 2.4 has greater "range" but is subject to "local" interference.  Ask your daughter to try and connect tablet and TV to each in turn and see which is the better one for each.  If that doesnt help - post back.
  • 7
Shellbag29
Message 6 of 10
 I can't log into to the hub... it says page can not be displayed
  • 10.32K
  • 281
  • 591
Forum Team (Retired) Emma_E
Message 7 of 10
Hi Shellbag29,
 Thanks for getting in touch. I am sorry to see you have had trouble with your connection.
I have taken a look and things seem to be ok from this side. It may help to try the following so we can rule some things out:
Pop the hub into Modem Mode with the computer in Safe Mode with Networking at different times of the day.
Try on separate devices.
Check Ethernet cable. Make sure it is new / up to date. (Cat 5e or above).
Make sure device is capable of agreed speed.
Check wireless card slide.
If you are trying to log into the hub try:
192.168.0.1 in the browser, log in  Username is admin and the password will be changeme, unless you have changed it.
Go to Advanced settings.
Go to Network Status
Take care.
 Emma
  • 7
Shellbag29
Message 8 of 10
I can't sign into the hub. That password wontbwork
  • 19.23K
  • 1.68K
  • 4.22K
Message 9 of 10
If your using a hub 3 need to use settings password on the hub if that doesn't work would need to press reset using pin hole for 30 seconds, just don't reboot hub during process
  • 7
Shellbag29
Message 10 of 10
I've renamed 2.4 and 5
My tv only finds 2.4...and only has 8mbps
