on 16-01-2022 15:51
We recently had Virgin Media installed (6th Jan) and have been having some issues with the wifi and performance etc - We have signed up for Volt Gig 1 Fibre Broadband. After reading about other users having issues with the Hub 4, I went and bought a router and used the hub in modem mode - This didn't seem to improve anything.
My partner is working from home and when she is on teams it is shocking! Video constantly freezes and is barely useable, same with facetime etc... This includes over wifi and wired connections. Now thinking this could be something to do with upload speeds? I've currently got my mac wired into the Hub 4 and below are the results from Samknows.
Answered! Go to Answer
16-01-2022 16:36 - edited 16-01-2022 16:38
Carl was right - your upstream connection is awful
Power levels all too high (~51dBmV is the recommended maximum) and the qam's should all be at 64.
on 16-01-2022 15:54
Here is a screengrab of the wifi speed - This is in the same room as the router, a foot or two away. Even when we get this upto around 2-300mbps, images don't load straight away on social media platforms etc.
on 16-01-2022 15:59
What are wired speeds like?
on 16-01-2022 16:02
Hi Gary,
The three screenshots in the first post are all wired into the Hub 4.
As well as the issues we are having I believe we should also be getting higher download speeds too? They are below the minimum guaranteed?
16-01-2022 16:07 - edited 16-01-2022 16:08
@ScottSudale88 wrote:Hi Gary,
Keep in mind minimum speeds are on wired devices, not wireless. There are too many standards across all wireless devices to be confident of the speeds you will get.
I have a feeling there is something wrong with your upstream channels, which can cause issues with downstream.
on 16-01-2022 16:31
Hi Carl,
All those speeds I posted are wired...
BQM here:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/463ee4fbfe07dca4c5fb374d5a651d0e39f2f0b6
Other results below...
1 | 46200000 | 58.8 | 5120 KSym/sec | 64QAM | 11 |
2 | 39400000 | 58.8 | 5120 KSym/sec | 32QAM | 12 |
3 | 53700000 | 58.8 | 5120 KSym/sec | 16QAM | 10 |
4 | 60300000 | 58.8 | 5120 KSym/sec | 64QAM | 9 |
1 | US_TYPE_STDMA | 0 | 0 | 2 | 0 |
2 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
3 | US_TYPE_STDMA | 0 | 0 | 1 | 0 |
4 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
on 16-01-2022 16:32
26 | 339000000 | 1.4 | 36.6 | QAM256 | 26 |
1 | 139000000 | 2.8 | 35.8 | QAM256 | 1 |
2 | 147000000 | 2.9 | 36.4 | QAM256 | 2 |
3 | 155000000 | 3.3 | 36.6 | QAM256 | 3 |
4 | 163000000 | 3.8 | 36.4 | QAM256 | 4 |
5 | 171000000 | 4 | 36.6 | QAM256 | 5 |
6 | 179000000 | 4.3 | 36.4 | QAM256 | 6 |
7 | 187000000 | 4.4 | 36.4 | QAM256 | 7 |
8 | 195000000 | 4.4 | 36.6 | QAM256 | 8 |
9 | 203000000 | 4.4 | 36.6 | QAM256 | 9 |
10 | 211000000 | 4.1 | 36.6 | QAM256 | 10 |
11 | 219000000 | 4 | 36.6 | QAM256 | 11 |
12 | 227000000 | 3.5 | 36.4 | QAM256 | 12 |
13 | 235000000 | 2.9 | 36.4 | QAM256 | 13 |
14 | 243000000 | 2.2 | 36.6 | QAM256 | 14 |
15 | 251000000 | 2 | 36.6 | QAM256 | 15 |
16 | 259000000 | 1.2 | 36.4 | QAM256 | 16 |
17 | 267000000 | 0.9 | 36.6 | QAM256 | 17 |
18 | 275000000 | 0.6 | 36.6 | QAM256 | 18 |
19 | 283000000 | 0.1 | 36.4 | QAM256 | 19 |
20 | 291000000 | -0.1 | 36.4 | QAM256 | 20 |
21 | 299000000 | -0.3 | 36.4 | QAM256 | 21 |
22 | 307000000 | 0.4 | 36.4 | QAM256 | 22 |
23 | 315000000 | 0.8 | 36.6 | QAM256 | 23 |
24 | 323000000 | 1.2 | 36.6 | QAM256 | 24 |
25 | 331000000 | 0.9 | 36.6 | QAM256 | 25 |
27 | 347000000 | 2 | 36.6 | QAM256 | 27 |
28 | 355000000 | 2.2 | 36.6 | QAM256 | 28 |
29 | 363000000 | 2.5 | 37.4 | QAM256 | 29 |
30 | 371000000 | 2.7 | 36.6 | QAM256 | 30 |
31 | 379000000 | 2.5 | 36.4 | QAM256 | 31 |
26 | Locked | 36.609653 | 0 | 0 |
1 | Locked | 35.779911 | 0 | 0 |
2 | Locked | 36.386890 | 0 | 0 |
3 | Locked | 36.609653 | 0 | 0 |
4 | Locked | 36.386890 | 0 | 0 |
5 | Locked | 36.609653 | 0 | 0 |
6 | Locked | 36.386890 | 0 | 0 |
7 | Locked | 36.386890 | 0 | 0 |
8 | Locked | 36.609653 | 0 | 0 |
9 | Locked | 36.609653 | 0 | 0 |
10 | Locked | 36.609653 | 0 | 0 |
11 | Locked | 36.609653 | 0 | 0 |
12 | Locked | 36.386890 | 0 | 0 |
13 | Locked | 36.386890 | 0 | 0 |
14 | Locked | 36.609653 | 0 | 0 |
15 | Locked | 36.609653 | 0 | 0 |
16 | Locked | 36.386890 | 0 | 0 |
17 | Locked | 36.609653 | 0 | 0 |
18 | Locked | 36.609653 | 0 | 0 |
19 | Locked | 36.386890 | 0 | 0 |
20 | Locked | 36.386890 | 0 | 0 |
21 | Locked | 36.386890 | 0 | 0 |
22 | Locked | 36.386890 | 0 | 0 |
23 | Locked | 36.609653 | 0 | 0 |
24 | Locked | 36.609653 | 0 | 0 |
25 | Locked | 36.609653 | 0 | 0 |
27 | Locked | 36.609653 | 0 | 0 |
28 | Locked | 36.609653 | 0 | 0 |
29 | Locked | 37.355988 | 0 | 0 |
30 | Locked | 36.609653 | 0 | 0 |
31 | Locked | 36.386890 | 0 | 0 |
159 | 96 | 4K | 1880 | QAM4096 | 424 |
159 | Locked | 40 | 1.8 | 16044907 | 0 |
on 16-01-2022 16:33
Thu 01/01/1970 00:01:25 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 16/01/2022 15:05:09 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 16/01/2022 15:06:12 | 6 | Received REG-RSP while in REG-HOLD1 state;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 16/01/2022 15:08:13 | 3 | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 16/01/2022 15:09:40 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 16/01/2022 15:10:04 | 5 | ToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 16/01/2022 15:10:19 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 16/01/2022 15:10:32 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
on 16-01-2022 16:42
And BQM looks terrible!
