19-10-2021 10:31 - edited 19-10-2021 10:32
I am having problems with the WiFi signal distribution in my home.
I have a smart TV in my living room and a laptop in my kitchen. These are essentially the same room because it's open plan.
My Virgin Connect app reports that the signal is "Great" at both locations but I am having issues with it. At times the laptop wifi indicator is down to the first dot and the TV drops out when streaming, etc. My mobile also shows no more than two bars even when I am sitting beside the router (Hub 3). The router is in my home office upstairs.
Is there a problem here or do I need to get some sort of a booster?
on 19-10-2021 13:14
19-10-2021 18:14 - edited 19-10-2021 18:17
Hi John,
This is the hub, The only light that shows when it is working is the bottom white/pink light.
My PC is connected via ethernet and there are no issues. It's only the wireless signals that are a problem.
on 19-10-2021 18:52
on 20-10-2021 09:32
"a "better" wireless solution" ?
on 20-10-2021 09:59
@bdw wrote:"a "better" wireless solution" ?
If you really want a solid wifi solution, you can either rent pods from VM. or buy you own solution. No ISP supplied Router is guaranteed to give wifi to every corner of every room. A lot of users here purchase their own wifi kit and don't use the Hub's wifi. Personally I use PoE Access Points and have no problems with wifi anywhere in my house.
on 20-10-2021 14:52
on 22-10-2021 14:59
Hi @bdw,
Welcome back to our Community Forums! Thank you for your post, and I'm sorry to hear that you're unhappy with your Hub 3 performance. We'll be more than happy to look into this for you.
Please let us know if this wireless issue happens across all WiFi devices in your home, or just some?
Have you taken a look at some of the advise provided on this thread?
Please let us know if you'd like any further assitance.
Thank you,
on 23-10-2021 09:42
As I said earlier my Virgin Connect app reports that the signal is "Great" at both locations but I am having issues with it. At times the laptop Wi-Fi indicator is down to the first dot and the TV drops out when streaming, etc. My mobile also shows no more than two bars even when I am sitting beside the router (Hub 3).
Other than moving the router around (within the confines of the cable length) I have not tried any of the other fixes.
on 25-10-2021 10:27
Thank you for your reply.
As a provider we are unable to gurantee WiFi throughout the property but we do offer equipment in order to help with this.
As other members have advised, there are option for you to purchase additional third party equipment or we also offer our own smart WiFi Pods.
More information on these can be found here
