on 22-02-2021 10:34
We recently had a power cut, where once power was restored my HUB wasn't providing Wifi, the wired ethernet connections worked. I had to do a hard reset of the HUB in order to get the Wifi working again. However, not my Intelligent Wifi Pods no longer connect. Can i get soem help with which settings should be adjusted.
thanks.
Answered! Go to Answer
on 23-04-2021 18:41
Thank you,
The light on the pods, can you confirm if they show any of the below-
blinking Fast
Double blinking
Light off
Pulsing (Dim to light)
Alex_Rm
on 23-04-2021 19:24
It’s pulsing continuously
on 23-04-2021 19:56
Thankyou,
Can you move the pods closer to the hub for me, and let me know if it continues to pulse?
Alex_Rm
on 23-04-2021 20:00
Yeah it’s exactly the same in the same room as the hub, prob about 5ft from it
on 23-04-2021 20:09
Thank you for all the extra information,
There appears to be a provisioning issue with the Pods you are using. This will need to be rectified by one of our FMS colleagues.
However, due to Covid 19 the department is not taking calls directly so I will pass on your details to the FMS team who will contact you back once they have worked the ticket.
Alex_Rm
on 23-04-2021 20:16
Great thank you
on 28-04-2021 11:27
Hello – we've not heard anything as yet, and it's proving a bit difficult working from home without it. Could somebody ring us today?
on 28-04-2021 12:49
Sorry to hear you haven't heard back from FMS yet and that it is impacting your work, please allow 5 working days to receive a response from FMS.
Please keep us updated when you hear back from them. Unfortunately we cannot arrange a time for a call back, I'm sorry.
Apologies for the inconvenience,
Serena
on 17-07-2021 08:12
on 17-07-2021 10:35
Good morning @PhilipF
Sorry to hear that you are also having issues with your pods, are you able to let me know if you also have be advised that the FMS will be in touch also?
Kind regards,
Zak_M
