on 13-07-2022 20:01
Just received my Pod today. Every now and then a white light flashes. Can’t see any difference. The virgin media WiFi boosters worked better.
on 13-07-2022 21:53
Try some different positions for the Pod. It needs to be in a place where it can receive a reasonable signal from the Hub, ideally half way to the room it needs to serve.
on 13-07-2022 22:17
If the pod was connected to your hub then there would be no lights on at all on the pod, also when the pod in connected it can take 24 hours for it to optimize.
When this is done what you want to connect to the pod needs turning off and on again or disconnected from your network and reconnected this way the device will connect to the strongest signal.
That way you may find an improvement in your wifi network
