Pfsense firewall and hub3
Andtheit
Hi has anyone got a guide to setting up a hub 3 in modem only mode and the settings needed on pfsense firewall?
anyone help would be much appreciated
thanks Andy
1 ACCEPTED SOLUTION
Accepted Solutions
Robert_P
Hello Andtheit
Thanks for posting in regards to your Hub and setting up modem mode. We appreciate you raising the query via the forums and welcome to the community.
Please follow the steps below for setting the Hub 3 into modem mode:
1. Navigate to 192.168.0.1
2. Log in to the Hub
3. Go to 'Modem mode' (on the left) and put the hub into modem mode
4. Wait until the bottom light on the Hub turns magenta / red (HUB 3) (can take about 5 minutes)
5. Turn off the Hub
6. Power on and set up your new router as per the manufacturers instructions
7. Plug an ethernet cable (usually supplied with the new router) from port 1 on the Hub into the WAN (usually blue) socket on the new Router
8. Power on the Hub and wait about 5-10 minutes until it stabilises - You should have internet!
3 REPLIES 3
pfsense should when you find what port is WAN and LAN work by default from what I remember
Robert_P
Hello Andtheit
5. Turn off the Hub
Thanks Robert_P will give it a go
