  • 97
Theagg
Message 1 of 9
Packet loss and latency spikes
Having mostly solved the speed issues I was having with my Vivid 350 (the technician fitted an attenuator which brought my downstream and upstream power levels back into optimum ranges) I have been running the Hub 3 in modem mode, with a TP Link Archer C7 as the router. (QoS off, Nat Boost on)
However, I'm seeing an awful lot of packet loss and latency spikes since doing that, so any suggestions as to what might be up. The BQM graph here certainly doesn't look as healthy as some I have seen posted on forums here..(this via wired connection) which may explain the occasional speed dips that still plagues me, though nowhere near as bad as before the attenuator was fitted. (For example this dramatic but short lived blip of a speed drop https://www.speedtest.net/result/8262856401)
bqm1.jpgbqm1
  • 97
Theagg
Message 2 of 9
Re: Packet loss and latency spikes
one upstream has dropped to 16qam I note
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
35800000
3.675
5120
64 qam
6
2
27399825
3.6710000000000002
5120
16 qam
7
3
53699938
3.725
5120
64 qam
8
4
45800000
3.675
5120
64 qam
5
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
298750000
-1.5
40
256 qam
21
2
170750000
-0.7
40
256 qam
5
3
178750000
-0.5
40
256 qam
6
4
186750000
-0.5
40
256 qam
7
5
194750000
-0.5
40
256 qam
8
6
202750000
-0.7
40
256 qam
9
7
210750000
-0.7
40
256 qam
10
8
218750000
-0.7
40
256 qam
11
9
226750000
-0.9
40
256 qam
12
10
234750000
-0.9
40
256 qam
13
11
242750000
-1.2
40
256 qam
14
12
250750000
-1.4
40
256 qam
15
13
258750000
-1.5
40
256 qam
16
14
266750000
-1.5
40
256 qam
17
15
274750000
-1.7
40
256 qam
18
16
282750000
-1.5
40
256 qam
19
17
290750000
-1.7
40
256 qam
20
18
306750000
-1.5
40
256 qam
22
19
314750000
-1.5
40
256 qam
23
20
322750000
-1.5
40
256 qam
24
21
402750000
-1.5
40
256 qam
25
22
410750000
-1.4
40
256 qam
26
23
418750000
-1.5
40
256 qam
27
24
426750000
-1.5
40
256 qam
28
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
40.3
18
0
2
Locked
40.3
6
0
3
Locked
40.3
23
0
4
Locked
40.3
23
0
5
Locked
40.9
17
0
6
Locked
40.3
15
0
7
Locked
40.3
5
0
8
Locked
40.3
5
0
9
Locked
40.3
9
0
10
Locked
40.3
6
0
11
Locked
40.3
19
0
12
Locked
40.9
10
0
13
Locked
40.9
8
0
14
Locked
40.3
20
0
15
Locked
40.3
14
0
16
Locked
40.3
11
0
17
Locked
40.3
7
0
18
Locked
40.9
9
0
19
Locked
40.9
6
0
20
Locked
40.3
11
0
21
Locked
40.3
9
0
22
Locked
40.3
8
0
23
Locked
40.9
10
0
24
Locked
40.3
2
0
  • 12.45K
  • 471
  • 1.11K
Message 3 of 9
Can't see your BQM yet can you post the live link.
Do you get any t# timeouts in the logs?
If you can copy the MAC of your router (TP Link Archer C7 ) to your PC/laptop NIC you can test with that to the modem mode port for a bit or go with another WAN IP by powering off the hub for 2mins.
You can run CMD with
ping -t 194.168.4.100
to see if packet loss matches up with your BQM.
  • 97
Theagg
Message 4 of 9
https://www.thinkbroadband.com/broadband/monitoring/quality/share/fab05f14bd89c43654379ba3baae2c60b28eb50b
  • 97
Theagg
Message 5 of 9
Every time i post the BQM links, I get error messages, can't seem to get the actual image to post...what exactly do I need to do to get that to appear, hmm, having tried numerous of the graph link options presented (Direct, small, large, BBCode)
No timeouts listed recently in the log and I will need a bit more explanation on exactly how and to where to copy the MAC address etc ! But I'm getting the feeling that the TP Link is not working well with the Hub 3., unless there are some specific settings on the Archer I have missed. Will do a BQM test tomorrow with the Hub 3 back in router mode to see if all those red spikes disappear.
  • 8.62K
  • 885
  • 1.34K
Message 6 of 9
Do a screen grab around the BQM, save it and post it.
  • 97
Theagg
Message 7 of 9
ok, lets see if the image posts this time, this one is still on the TP Link up till 11am (wired to PC, Cat 6A) The image posted last night has finally appeared (see above). Will now switch Hub 3 back to router mode to test those packets..
  • 491
  • 26
  • 102
tonycv51
Fibre optic
Message 8 of 9
Faulty equipment or line / noise problem looking at those lost packets.
As well as trying the hub in router mode suggest check coax into hub is properly tight and if still getting lost packets then call in a fault or wait for VM to reply on here.
  • 97
Theagg
Message 9 of 9
Well, I didn't get round to swapping the Hub back to router mode (gardening and stuff!) but interesting to note that even though nothing was changed or touched the packet loss abruptly disappeared at midday. See BQM image for today. That's with the TP Link still connected, the PC on all day (as yesterday), no cables touched, no reboots, nothing.
So, is that change indicative of some issues with Virgin that were resolved ? Some random 'noise' event that ran all yesterday and till midday today, then ended...About the only change that occurred is that around 11am, I turned the PC on for the day, it having been turned off at around 2.30 am on that graph...very odd
graph 2.jpggraph 2
